Does your BOV hold Boost?? What are you using?
Old Aug 13, 2007 | 01:35 PM
MIVEC8's Avatar
Mine didn't. I had a brand new Agency Power BOV on my Evo w/ no issues. When it got to the dyno w/ the boost cranked up [I'm not sure how much because I haven't picked up the car, to 22-23 psi I'm guessing] it didn't hold boost.. I picked up a JDM MR BOV to overcome this issue and it held just fine. But I guess what I'm looking for is for folks to list what they have and how well it works. So if you don't mind list what BOV you are using, how much boost you are running and any issues you had w/ your BOV if any. The obvious choice for most will be the JDM MR. But I'm also interested to see what others will hold more boost. Thanks.
No I'm not a "ricer". I recently had a ton of mods installed and this one mod was the weak link. I upgraded because I had a plastic OEM bov and I got a great deal on the AP bov. Once I get the car back I'll post the graphs and the numbers it made. Thanks for your help.
Maybe this will help others as well, as far as letting them know what BOV not to purchase.
Old Aug 13, 2007 | 01:46 PM
travman's Avatar
I boost leak tested an evo that had an aps dual vent p.o.s and it didnt hold boost. It leaked out the adjustment screw on the top, he took it off an bought a stock IX bov.
The stock IX (jdm MR) is a great bov and will hold boost well for most people and then you can modify it by crushing (1G dsm trick) to hold a little more boost or "Gus Mod it". http://www.thedodgegarage.com/turbo_bov_mod.html
Old Aug 13, 2007 | 01:57 PM
MIVEC8's Avatar
Another issue w/ aftermarket bov's is the flutter (surge) at part throttle. That sucks. Doesn't sound too nice either. That's where the MR BOV shines.
Old Aug 13, 2007 | 02:21 PM
EVIL MR's Avatar
forge rs.
Old Aug 13, 2007 | 02:24 PM
CrackerJackToy's Avatar
forge diverter ftw here!
Old Aug 13, 2007 | 02:27 PM
flevo8's Avatar
Yes, Tial.
(on AEM)
Old Aug 13, 2007 | 02:54 PM
Illrunya's Avatar
Forge RS FTW!
At first the flutter was rediculous, but thanks to the adjustability, I got it to a point where the boost is held and the part throttle is nearly perfect.
Old Aug 13, 2007 | 03:23 PM
C6C6CH3vo's Avatar
Hold's whatever is behind it.
It's a stock valve that I added an additional port (under diaghram) solenoid controlled which is energized by the throttle VDC option in the IC relay parameter. Tried to explain as simple as possible but it works like stock if TPS < 2.2 volts and holds solid if >.
I had the rs which was OK but sold it because I didn't like the normal drive flutter characteristics.
Old Aug 13, 2007 | 03:31 PM
Smike's Avatar
Thats not surge. See Valve Fluttering in post 2.
https://www.evolutionm.net/forums/sh...hreadid=209640
I have run both the Greddy Typs S and the Forge RS (current). And also have not seen issues with the APS unit locally. But I have been more than happy with the Forge RS.
Old Aug 13, 2007 | 03:53 PM
Luis@TTP's Avatar
greddy type s yes install alot of forge evo15 vales they work well also sisters to the forge rs and arent on back order like them.
Old Aug 13, 2007 | 04:00 PM
LilRico's Avatar
Forge Recirc. FTW.... My IX BOV was leaking bad... The Forge took care of that, and no flutter!!!
Old Aug 13, 2007 | 04:34 PM
Bonestock!'s Avatar
I use a Evo IX FQ-340 BPV up to 25psi (when setting my MBC up) and it held fine. Though I do get a bit of part throttle flutter. And yes its annoying.
Old Aug 13, 2007 | 04:39 PM
xiaoni420's Avatar
My stock IX valve works great for boosting 29lbs.
Old Aug 13, 2007 | 06:14 PM
Yme's Avatar
Yme
Tial here
Old Aug 13, 2007 | 06:44 PM
LoCo4's Avatar
Forge diverter here.....23 psi spring has held up to 25 psi.
