Ticking On Deceleration!!!
Old Aug 13, 2007 | 04:31 PM
1.8tfanatic's Avatar
Alright guys I can really use some help here.I'm going to try to word it as good as possible! I have a built 05 evo8(bottom end, buschar racing stage3 head etc. etc.272 cams and a lil nitrous NEVER SPRAYED YET) I started to hear a slight tick over the head and figured a lifter was starting to dump! So I ordered JAM Lifters and in the week it took for them to get in, like a dummy i was driving the car and ticking started to get worse. Finally lifters come in, install them, and still a loud tick on deceleration and dies out at idle but still I can hear a little bit at idle. It sounds like its coming from the head but with a pair of stethoscopes you can hear a noise from almost anywhere, i put them on the( BLOCK, TRANNY, HEAD A LITTLE BIT, INTAKE MANIFOLD) I really just wanna know if anyone has had this problem before, and i can go straight to the problem and fix instead of taking the whole motor apart (which i think i'm gonna have to do anyways )
Sorry if it was a long post, but i can really use some help! Much appreciated
Old Aug 13, 2007 | 07:27 PM
Anyone?
Old Aug 14, 2007 | 03:43 PM
alpha's Avatar
What injectors are you running?
Old Aug 14, 2007 | 04:34 PM
Hey!
Hey alpha i was thinking it was the injectors but i dont know, im still running stock injectors and i've been running them maxed out for a while could that be the problem? is there a way to check that?
oh and the cars has been going through plugs and leaning out on me breaking up under load
Old Aug 14, 2007 | 05:24 PM
alpha's Avatar
Could be the injectors. I would see if you cant rule those out. Take a couple hours this weekend. Swap out the injectors Have had it happen before
Old Aug 14, 2007 | 06:30 PM
Man i hope thats the problem. I really dont wanna take the motor out again! ill keep you updated... Thanks for the help
Old Aug 14, 2007 | 07:05 PM
spikek1's Avatar
Hey im not an expert but i would also suggest the injectors. if for some reason there is something wrong with one of your injectors, your engine may be running lean. Sometimes if your engine runs to lean it causes the piston to expand and scratch against the cylinder wall, and that may be your ticking. The same thing happened to by brothers dirt bike, but thats a completely different engine type and situation. but just my theory.
good luck with the problem, i hope everything works out for the best.
Old Aug 16, 2007 | 03:26 PM
Umm
Well its not the injectors , it sounds more of a deep loud ticking noise coming from the front of the head(Exhaust manifold side). Im just going to take it to the shop to get it checked out thanks for the help guys!!!
Old Aug 16, 2007 | 05:27 PM
But
But if anybody might know what it could be please feel free to post up thanks guys very big help!!!
P.s i've taken it to a couple places and a couple friends that are mechanics and they all say its lifters( cause thats what it sounds like) but Like I said i Jus in stalled JAM lifters in the car, had a master tech install them. again any help is great!!!
Old Aug 17, 2007 | 07:46 AM
alpha's Avatar
Were the lifters bled when the cams went in?
Old Aug 17, 2007 | 07:51 AM
Pure Playaer's Avatar
Its a time bomb.. Pretty much its all in your head preparing you for when you spray the NOS, the motors gunna blow
JK.. sorry I couldnt be of any help.. I figure humor might enlighten the situation lol
Old Aug 27, 2007 | 09:18 PM
MR EVOL MAN's Avatar
the same thing is happening to my car right now...i havent even done anything major to it...i only have 15000 on my 9 mr...its making a ticking noise starting at 3000 rpm then when i put it on nuetral it goes away. I'm going to take it in tomorrow because I talked to one of the mitsubishi mechanic and he said it could be the lifters..i will post the results tomorrow and see if have the same problem as me...peace
Old Sep 4, 2007 | 09:40 PM
hey
Did ya fix the problem?
Old Nov 4, 2007 | 05:51 AM
chaz517's Avatar
my car ticks too, rather annoying
Old Nov 11, 2007 | 08:46 PM
blackoutVIII's Avatar
my car ticks too on acceleration. the noise comes from the left side. especially when i am going uphill. so what can this be? only mods are on my sig. i only have 21k miles.
Hassan
103
Aug 5, 2023 11:37 AM
Spoolin4g63
Jun 17, 2015 09:43 AM
Ichigo0Soul
21
Mar 26, 2014 05:43 AM
Evolution 8 MR
Dec 1, 2012 11:53 AM
dipsetinallday
Jun 28, 2009 11:28 AM
