What to do if any before tune?
Old Aug 14, 2007 | 10:28 PM
Tracer's Avatar
I have a IX MR w/3"dp,tp,catback, intake on and MBC and Walbro ready to put on. Is there any one part also to do before a tune or just stay with what I have for now. I am just not sure about ic pipes etc if they really give you that much of a difference. I will get cams in a couple months and have to retune but for now this is what I have unless there is enough proof that one other part will say persuade me to buy it before the tune.
Old Aug 14, 2007 | 10:53 PM
RevMoto's Avatar
A great mod would be a meth kit. Also I am planning on running an ets 3.5 in FMIC kit to go along with it. Also you can add an 02 housing and ported manifold.
Old Aug 14, 2007 | 11:02 PM
Nad1370's Avatar
Make sure you do not have any boost leaks.
Good fuel in the tank.
Plugs not misfiring.
Old Aug 14, 2007 | 11:06 PM
cpoevo's Avatar
^^ Double what he said. I am getting tuned on Thu and did a boost leak test and found a small tear in a vacuum line and found a T fitting that was leaking. Never would of thought of those leaks. Take new pluigs with you just in case.
Old Aug 14, 2007 | 11:08 PM
SilverShadow03's Avatar
^What he said and....
do an oil change (unless recently changed), check your air filter (clean and/or replace if needed) and check all fluids.
Old Aug 14, 2007 | 11:22 PM
IEXCELR8's Avatar
BR EVOLUTION MAF PIPE KIT
EVOLUTION ODYSSEY MINI BATTERY KIT
BR EVOLUTION UPPER I/C PIPE KIT w/ FORGE MOTORSPORTS BOV
stage 2
Old Aug 14, 2007 | 11:35 PM
Tracer's Avatar
What about Nisei u/l ic pipes. That would be cool to some u/l ic pipes w/ a flange for an forge rs bov.
Old Aug 14, 2007 | 11:44 PM
sparky's Avatar
If you're getting a pump gas tune, then the stock IX DV will hold fine. Get the lower IC pipe and a Buschur coated O2 housing as well.
Old Aug 14, 2007 | 11:45 PM
Nad1370's Avatar
Sure why not. If you have more money to spend.
But numerous 9's are in the 11's and easy low 12's with the mods you already have.
I'd prob. save up for a meth/alchy kit, cams or a clutch.
Your $$ your choice I guess.
Old Aug 15, 2007 | 12:16 AM
Tracer's Avatar
I do like the idea of just the licp and coated o2 housing not sure what the whp gain would be, hopefully at least 15 post tune.
Old Aug 19, 2007 | 11:42 PM
Tracer's Avatar
Went ahead and ordered the Buschur licp, and O2 housing. We'll see what a catless tbe, apexi intake, licp, O2 housing, mbc, walbro can get my IX post tune. Any guesses?
Old Aug 20, 2007 | 02:58 AM
evoixbri's Avatar
get an aftermarket intake pipe by aem,hks,buschur to go with the apexi filter. that's what I did and I felt a difference in throttle and cool turbo spool sound. u should hit 340-350whp with that setup post tuned.
Old Aug 20, 2007 | 08:29 AM
Boltz.'s Avatar
FCOTM Winner
The BEST thing you can do before a tune is to tune the car up. Fresh oil, Fresh Plugs, Boost leak test, Check for exhaust leaks, etc etc etc
Old Aug 20, 2007 | 10:07 PM
Tracer's Avatar
Do I really need new plugs with only 4K miles?
Old Aug 20, 2007 | 11:04 PM
XSivPSI's Avatar
No. You're fine. You know you didn't have to ask
2009RGRalliArt
Mar 16, 2017 11:03 AM
Nelson999
20
May 25, 2011 10:22 AM
Chabada15
May 1, 2008 12:28 PM
evilevo22
Oct 3, 2007 02:36 PM
Tracer
May 3, 2007 12:34 AM
