$#%&ing sound!!
Old Aug 17, 2007 | 02:31 PM
jbm7777's Avatar
I have a feeling its the clutch, I recently got an ACT streetlyte flywheel and exedy stage 1 clutch and it rattles when I start, and at low RPMs. I also have a downpipe that rattles against the cross member a bit, but its better than the transfer case that it used to rest on.
Old Aug 17, 2007 | 02:52 PM
AOR's Avatar
AOR
Originally Posted by Jeff_Jeske
Why not have a friend listen for the noise. To find odd noises I use a 4ft section of garden hose. One end on my ear the other eng gets moved around the engine bay. It works like a stethoscope.
It wouldn't take much work to put the tie bars off or at a minimum inspect the dowpipe/oil pan :: downpipe/tie bar clearances. Remember SS parts expand when hot. If you don't hear the noise when the car is cold but do when its hot odds are its exhaust related.
If it is the DP rubbing on the oil pan, transfer case, or tie bars you're probably getting mechanical knock too. Best to hunt this down to recover some hidden HP!
Or
Go to walmart and buy a digital camera with video and sound. Use it to make a video of the noise. Post the video. Return the camera. Wait for advice from others.
My gf is over right now, and we are going to use her camera =] will post sounds later tonight.. Also it can't be the two tie bars, because i don't have them on =].. the ams downpipe doesn't clear so we took it off. dont worry getting some washers and putting em back on shortly. my friends have all tried listening to it for me.. sounds like its coming from the downpipe area, but that's impossible... we've even got UNDERNEATH the car.
Originally Posted by tripperfx3
Id go with clutch noise. I know you have an aftermarket clutch, but i made a thread about this just recently and consensus said its just a normal noise with the car whether the clutch is stock or aftermarket. Mines been doing it for a little over a year and ive had no problems. Mine also gets louder when i turn the AC on, so see if that happens.
i'll give that a try when i record.. the thing is is it possible for the clutch to make noises when my cars in nuetral? flywheel i'd assume so, but the clutch isn't even engaged?
does it rattle even when ya rev in neutral?
Old Aug 17, 2007 | 10:15 PM
AOR's Avatar
AOR
finally have sound clips
hey fellas.. all input has been greatly appreciated.. finally got some sound clips.. not the best of quality as it is with my gf's camera. try to hear for the vibrating/hissing sound.. it's almost like a "zzzzzzzzzz" "zzzzzzzzzzzzz" you might be thinking it's the bov, but it isn't entirely.. help!
http://www.youtube.com/watch?v=vEznYF2OhnU
http://www.youtube.com/watch?v=S_9ESS99980
Old Aug 17, 2007 | 11:22 PM
Nad1370's Avatar
def. sounds like from the exhaust.
Check heatsheilds in the undercarraige or missing heatsheild bolts around the exhaust manifold.
Check the whole exhaust piping if it's hitting anything.
If you can get underneath your car safely. Have your GF duplicate the noise and you can pinpoint where it's coming from.
Old Aug 18, 2007 | 12:07 AM
AOR's Avatar
AOR
hmm highly doubt it's the exhaust as i just swapped out the whole entire thing for a turboback and was just under it.. swapped out to a new turbo so the exhaust manifold came off as well...
Old Aug 18, 2007 | 01:50 AM
tripperfx3's Avatar
Something may be loose or rubbing. Check the downpipe clearance and make sure its not hitting the driveshaft while your at it.
Old Aug 18, 2007 | 02:14 AM
SpeedJunkyz's Avatar
You wouldnt happen to have dropped a nut, screw, bolt, etc inside the exhaust pipes anywhere would you? I dont think its the bearing, My throw out is needing replaced right now and mine sounds like a supercharger when the clutch it out. Do you have your pipe on the hanger tight? How did you get your lower sway bars on? Did it fit without any adjustments? My dp is custom and I actually have to jack the dp up in order to get my bars back on. If you had to do that it could be you loose sway bars rattling.
Old Aug 18, 2007 | 02:35 AM
AOR's Avatar
AOR
positive there wasn't anything dropped.. i actually had this noise before i installed the new turbo back.. as for the lower tie braces, they aren't even on the car right now. plan on getting some washers. i'm 100% sure it isn't the exhaust.. it's such a irritating sound.. i know it's nothing serious, but it's driving me ntus
Old Aug 18, 2007 | 02:56 AM
Hmmm I will look at my car and see if I can think of anything
Old Aug 18, 2007 | 03:06 AM
my guess is the clutch setup, Mine rattled like that right before it blew out. I had chadder for the longest time when in neutral, and sometimes when engaged. Then one day soon after (not sure how long) I didnt time it, but I would say like5000 mi give or take, it blew out. Left me stranded on the side of the highway. I felt it going though, it would slip like crazy between 3-5 k rpms
Old Aug 18, 2007 | 06:11 AM
Sully 18's Avatar
what tq and tq pattern did u put the clutch on
Old Aug 18, 2007 | 09:17 AM
AOR's Avatar
AOR
appreciate it bud
i will try reving the car up with clutch pressed down.. doesn't sound like a clutch issue tho?
actually had the clutch done at a shop... watchu mean tho?
Old Aug 18, 2007 | 09:31 AM
Nad1370's Avatar
I didin't mean the actual exhaust.
What I meant was the heatsheilds underneath the car that are vibrating because of a loose/missing bolt or nut to hold it in place.
Was the noise there before the clutch swap?
Did they replace the throw out bearing?
Old Aug 18, 2007 | 10:11 AM
AOR's Avatar
AOR
ya i know what ya meant.. i checked everything under the car.. seemed to check out. the noise wasn't there before the clutch swap.. however it wasnt there after it either... i got my clutch changed a looong time ago and the noise didn't come until recently.. they better have replaced the TOB, i told them too even tho i didn't provide one
Old Aug 18, 2007 | 10:20 AM
Jeff_Jeske's Avatar
I hope its not the flywheel coming loose!
