Need suggestions of possible problems! HELP!
Old Aug 18, 2007 | 10:13 AM
EVIL_EVO_VIII's Avatar
Ok let me start by saying that this isnt my car, im posting for my friend. So last night i was waiting for my friend and he calls me and told me he was driving normally and all of a sudden the car just shut off and wont start... I met up with him and we thought the fp went out, i had my oem fp in my car so we swap them out realy quick.. Tried to start the car again and it kinda wanted to start and then there was clicking sounds coming from the motor. Sounded to me like bent valves but im not 100% sure on that.. We checked all the ic piping and nothing. Checked all the fuses also.. In the last 2 days he installed a fmic and a HKS DLI so im not sure what ****ed up. His mods are the EXACT same mods except he has a fmic with intake and ic pipes and HKS DLI
Old Aug 18, 2007 | 10:17 AM
Update:
He just called and pulled out the spark plugs and one of them was broken completely.possibly the piston hit the spark plug.. Dont know what could have caused this when he was cruising normally
Old Aug 18, 2007 | 10:21 AM
EVIL MR's Avatar
that happened to me 1 time I was doing a top speed run and it just shut off at like 140 not fun at all, but mine started back up fine. It been about 8 month and it never did it again went all the way to 176 a few times after that.
Old Aug 18, 2007 | 12:01 PM
bump
Old Aug 18, 2007 | 12:13 PM
Nad1370's Avatar
Compression/leakdown test is your next move.
Did you ask your friend what he was doing before he told you he "was just cruising" when it happened?
Old Aug 18, 2007 | 12:48 PM
No, he just said he was driving normally and the car just gave out... Theres metal shavings when he took out the spark plug, im assuming its from the plugs its self and hopefully not from the piston... Hes about to put new plugs now and see if it starts
Old Aug 18, 2007 | 01:24 PM
We changed the spark plugs and no luck.. Also there little metal shaving in the oil.. Im guessing that the spark plug that broke was done when the piston hit it.. He said when i got there last night that the fuel pump may have gone out so another possibility is that the car ran lean and cracked a piston when the pump went out
Old Aug 18, 2007 | 01:37 PM
Well, its official, the motor is blown.. Piston #4 has big hole in it
Old Aug 18, 2007 | 01:50 PM
BlueDemon's Avatar
Ouch! That's gonna cost him
Old Aug 18, 2007 | 01:56 PM
ExViTermini's Avatar
stock pistons? Seen it happen on numerous cars including one of my friends. Do a search on it and you'll see there are quite a few on here. The stock pistons seem to have air pockets or something in the casting and makes them weak and they tend to break.
Best of luck to him.
Old Aug 19, 2007 | 12:33 PM
Yes its stock pistons..Its pointing pretty much this point at the fp failing and the car running lean
sobo
13
Oct 2, 2010 10:38 AM
Redline06
May 29, 2010 08:43 AM
got boost??
May 21, 2008 12:51 PM
NocturnalEVO
Dec 24, 2006 12:28 PM
