Major Boost leak
Old Aug 19, 2007 | 09:03 PM
TTP Engineering's Avatar
There is nothing wrong with the boost controller. If it was full open or broken it would boost 12-14psi minimum. If you are boosting below that, you have a coupler loose or vacuum line detached.
Old Aug 19, 2007 | 09:04 PM
TKEVO's Avatar
Veteran: Air Force
Thanks alot.
Old Aug 20, 2007 | 03:37 PM
Box Rocket's Avatar
I've been searching and have read this entire thread also. I am completely stock and I'm boosting about 16psi. I've wondered if it's just the heat since we've been almost 100* for quite a while. But I've wanted to check for leaks. Do I need to pull the front bumper to check the lower IC pipes?
Old Aug 20, 2007 | 05:33 PM
merkzu's Avatar
You can't just look at the pipes and see if there is a leak. You need to make a boost leak tester like in my previous post (~$10), hook an air compressor up to it and listen for leaks
Old Aug 22, 2007 | 07:17 AM
TKEVO's Avatar
Veteran: Air Force
Thanks for everyone help. I was able to find the problem in the leak. The flex pipe that connects to the intake manifold was leaking. Problem fixed for the moment but Im getting hard pipes 2day. Thanks everyone.
Old Aug 23, 2007 | 11:22 AM
bluebyu36's Avatar
thats were i told u to check in my first post......
Old Aug 23, 2007 | 09:39 PM
TKEVO's Avatar
Veteran: Air Force
yea. we did the whole test. i took your advice though
Old Aug 24, 2007 | 07:46 PM
reef_420's Avatar
Have you put a new blow off valve on? Check to see if the valve on the bov is stuck open. It happened to me and i could only run like 5 pounds.
Old Aug 25, 2007 | 12:23 AM
TKEVO's Avatar
Veteran: Air Force
Problem has been fixed. It was the intake manifold hose/clamp
2005evo8gsr
Oct 16, 2010 02:41 PM
voidhawk
Apr 4, 2008 12:44 PM
KevinD
11
Oct 4, 2006 06:18 AM
dsmfan95
Jul 20, 2006 08:36 AM
dbdude
15
Jul 4, 2006 10:27 PM
