my engine blew....any thoughts and help?
Old Aug 23, 2007 | 12:00 PM
  #196
shivaswrath's Avatar
so then getting a pair of GSC S1's with strong midrange power and limiting revving your Evo to 7krpm should satisfy the need for power AND insure non-stretched rod bolts?!
Old Aug 23, 2007 | 12:09 PM
  #197
GHEvo8's Avatar
same thing happened to me bro, cruzing and bam, i also had the fp green and smc kit, i feel your pain
Old Aug 23, 2007 | 12:11 PM
  #198
GHEvo8's Avatar
Hmm
Old Aug 23, 2007 | 12:18 PM
  #199
Thegame's Avatar
That's still just crazy how cast iron ends up with a hole the size of a baseball in it. I wonder what the new 4B11 will look like when I see the first Evo X "I blew my motor" thread.
Old Aug 23, 2007 | 02:44 PM
  #200
C6C6CH3vo's Avatar
Originally Posted by TTP Engineering
, superior Shurflo pump
EPDM or Viton?
Old Aug 23, 2007 | 04:10 PM
  #201
TTP Engineering's Avatar
Originally Posted by C6C6CH3vo
EPDM or Viton?
EPDM, are you testing me?
Old Aug 23, 2007 | 06:27 PM
  #202
C6C6CH3vo's Avatar
Nope, just wondering
I just got one of those EPDM Shurflo's
Old Aug 23, 2007 | 08:09 PM
  #203
EVOclub4's Avatar
thanks guys...now im getting a general idea of the problem....SO,
rod bolts were my problem...now i know......and now that i know wut it was that caused the problem, i can literally see that action unfold slowly in my head.....
kinda like that spike tv commercial where a UFC fighter got knee'd in the face, up against the fence, played in slow motion playing that song "This Is A Man's World" by James Brown
only in my situation.................aaahhhh! nevermind
but hey time for a build up....or purchase a fully built motor
Old Aug 23, 2007 | 09:06 PM
  #204
C6C6CH3vo's Avatar
The OEM torque to yield rod bolts it seems from the above posts have a rpm limit where forces of inertia exceed the clamping force.
The bolts are stretched on when installed at manufacture. I'm curious what this clamping force is and most of all, the rpm required to overcome it. Is there any one capable of doing that math? This would confirm the need for ARP rod bolts.
On the other hand all that would be needed to have a bolt stretch under normal use is excessive friction while torquing the bolts resulting in less clamp pressure
Old Aug 24, 2007 | 07:06 AM
  #205
98autogstspyder's Avatar
I would like to know the answer to this too. But I doubt it would be that simple to just put a number on it (not like the equation would be simple) but in this type of situation there are usually so many other factors.
Lets think for a second though. From what I understand, factory rev limit is set to 7400. When many tuners flash your ecu, often times they move the rev limit to 7800. So my guess is it must be around that 8200 rpm range...
Lets not forget that his motor may have simply had a defective rod bolt. Always a possibility.
Old Aug 24, 2007 | 07:07 AM
  #206
So is this the general consensus. Rod bolt failure? Whether it was stretched or defective? And like stated before, if it were not defective, what rpm does this sort of thing happen on a stock motor?
Old Aug 24, 2007 | 08:05 AM
  #207
bboypuertoroc's Avatar
Veteran: Army
Factory rev limit is 7606.
Old Aug 24, 2007 | 08:12 AM
  #208
Thegame's Avatar
well, what was the OP revving to?
Old Aug 24, 2007 | 08:53 AM
  #209
8thWonder's Avatar
Originally Posted by davidbuschur
Looks even more like a rod bolt failure................
My next trip up I'll be having you guys installing some rod bolts...
just in case...
Old Aug 24, 2007 | 02:32 PM
  #210
EJEvo's Avatar
ARP Con Rod bolts were one of my first mods, recommended by Dynoflash. Pruven Performance was able to install them by dropping the oil pan, so it wasn't that expensive. I'm always bouncing off the rev limiter in 1st gear at autocross events, and I've been trouble-free for 4 years. My condolences to the OP - good luck with your rebuild.
