my engine blew....any thoughts and help?
Old Aug 21, 2007 | 12:41 AM
  #136
EVOclub4's Avatar
Originally Posted by bboypuertoroc
I agree... get it off ASAP.
That (obviously) means there's no tension under the cam, which means more than likely it's busted to hell in there. Have you at least removed the valve cover?
haha .....!!! no not yet....i was so in the moment to just take apart everything to get ready for the cherry picker...
but now that this belt was brought to my attention, i just may take off that valve cover........................after the car show
Old Aug 21, 2007 | 12:43 AM
  #137
bboypuertoroc's Avatar
Veteran: Army
Still planning on going? LOL... awesome.
You might as well take if off now just to diagnose. Your car doesn't need to be there until when, Friday? That's plenty of time.
Old Aug 21, 2007 | 01:03 AM
  #138
AlohaEvo's Avatar
my thinking is if the crank comes to a sudden stop like it would if you send a rod through the block then it's bound to tear some teeth off the timing belt. Not sure if that's the cause of the big bang
Dylan, I just noticed the 3rd line in your sig... funny isht.
lol
Old Aug 21, 2007 | 01:04 AM
  #139
AlohaEvo's Avatar
so are you still going? how?
Old Aug 21, 2007 | 01:36 AM
  #140
EVOclub4's Avatar
yupperz...broken motor and all...but hey?! it's somewhat show ready.........third's friend is going to hopefully tow it down there for me and then all we have to do is push it into position
Old Aug 21, 2007 | 06:24 AM
  #141
TTP Engineering's Avatar
The piston to valve contact broke the tbelt.
The intake spins freely because all of the valves are bent and there is no cylinder pressure. Furthermore its likely all of the rockers popped out.
Old Aug 21, 2007 | 06:33 AM
  #142
milo's Avatar
That suxs, hopefully you'll get her running again
Old Aug 21, 2007 | 07:31 AM
  #143
Jeff_Jeske's Avatar
^ Ouch.... if the belt broke that probably means all the valves/pistons had contact with each other. Not good.
I've lost cap studs before and tossed a piston into the valves but it never killed the timing belt. In fact the car was still able to hold 85mph running on 3 cylinders until the rod eventually punched through the oil pan.
This motor is done no way to rebuild it. I'd start looking for a cheap replacement 4G63 to toss in there.
Old Aug 21, 2007 | 08:02 AM
  #144
Veteran: Army
^+1. You got that link I sent you Carlo? Also, I know for HIN your car has to be able to drive on and off the show floor on it's own power... don't know if SCS is gonna be the same way. You might want to check that out.
Old Aug 21, 2007 | 10:13 AM
  #145
Thegame's Avatar
Originally Posted by Mivecless
You have got to be the biggest idiot in the forums for the month of August.
I just wanted you to know that you are making an *** of yourself and have been mocked by every knowledgeable poster in this thread. You have proven to have no experience in the subject yet you spew your diarhea from the mouth.
Please do the forum a favor and stop posting as I feel dumber each time I see a post of yours.
Thanks
Old Aug 21, 2007 | 10:21 AM
  #146
Thegame's Avatar
I don't understand how the pistons could contact the valves on the intake side and pop the rockers loose but not the exhaust side. At either rate, I've never seen a timing belt ripped to shreds like that!
Old Aug 21, 2007 | 10:34 AM
  #147
Each valve has its own rocker. The intake and exhaust valves open at different times.
Old Aug 21, 2007 | 01:49 PM
  #148
AlohaEvo's Avatar
no good...
Old Aug 21, 2007 | 02:03 PM
  #149
Veteran: Army
no good...
No ****...
Old Aug 21, 2007 | 02:20 PM
  #150
sharkm87's Avatar
rip this thing apart already.
