HKS Evo IX cams and tune results
Old Aug 22, 2007 | 11:09 PM
mattsgto's Avatar
Ok here it goes. I posted this already on the norcalevo forums so I thought I'd post it here.
Mods before cams:
TBE exhaust, fuel pump, drop in filter, ecuflash tune I made 285whp on 91 octane (yes crap gas)
Added 720 injectors HKS Evo IX 272 Cams
It's summer so temp's were in the low to mid 90 degree area on 91 octane gas
300whp/300ftlbs
Car feels great and pulls hard. Obviously with better gas I'd do better but in Cali 91 is what we have to work with. Later I'll do a race gas dyno but for now I wanted to post the pump gas results. Andy sampled the car to 7400rpm hense the drop off in the end
Old Aug 22, 2007 | 11:15 PM
scheides's Avatar
EvoM Moderator
Great numbers! That's almost exactly what my VIII w/ HKS 280's makes. You don't by chance have a graph from before the cams on this same dyno?
Old Aug 22, 2007 | 11:16 PM
SPOOLED IX MR's Avatar
that sucks your stuck with 91 =\ IDK how you do it
Old Aug 22, 2007 | 11:19 PM
mattsgto's Avatar
cams
unfortunately I don't because the injectors were installed at the same time as the cams so the retune was needed pretty much right away.
Old Aug 22, 2007 | 11:20 PM
Cali2MDevo8's Avatar
Registered User
No MBC? How much boost are you running? I'm just trying to figure out how much loss is attributed to the 91 octane gas.
Why did you choose to change your injectors? I'm sure the stock ones would have been fine with your mods.
Jason
Old Aug 22, 2007 | 11:30 PM
mattsgto's Avatar
Jason
I don't have the other sheet on me but I believe its a 23psi spike tapering down to 20 psi and past 6000 down to 18. It was suggested i pickup a gm solenoid. I'll grab the other sheet tomorrow I think its in my glove box. Yes I have a hallman mbc. I was told my injectors were pretty maxed out and planned for future mods so I went ahead and picked up the 720's.
Old Aug 22, 2007 | 11:40 PM
Registered User
I'm not a tuner by any means but I'm surprised to hear that your injectors were maxed out on a mildly modified evo. Anyways, the 720's are a good upgrade incase you go Green.
Jason
Old Aug 22, 2007 | 11:48 PM
mattsgto's Avatar
Jason
Funny you say that because that's what I had in mind. But regardless given the circumstances I'm happy with the gain I have with cams. The power comes on pretty damn fast now and just goes
Old Aug 22, 2007 | 11:55 PM
Registered User
It's addictive. It will never end now
Old Aug 23, 2007 | 09:08 PM
DBPLAYA00's Avatar
nice job. now time for FP GREEN
Old Aug 24, 2007 | 07:39 AM
LIL EVOL's Avatar
Nice numbers! I made very similar but no 02 Housing and it was 121 deg inside...seriously.
http://s185.photobucket.com/albums/x...gDyno-Cams.jpg
Old Aug 24, 2007 | 07:56 AM
Soon2BEVO's Avatar
What temperature was it when you dynoed 285whp?
Also, something is wrong if you were "maxxing out" your stock injectors with your mods.
Old Aug 27, 2007 | 08:40 AM
Jeff_Jeske's Avatar
Did you retune after the cams?
Did you change boost after the cams?
Are you using the stock O2 housing?
Old Sep 6, 2007 | 02:31 AM
Jax419's Avatar
^^ +1 on was the boost changed after the cams?
Old Sep 6, 2007 | 08:02 AM
Recks's Avatar
Nice.. Well I knw roughly now what numbers I would get with cams alone
