Full Fluid Change. Fluid Suggestions.
Old Aug 23, 2007 | 09:57 AM
Pure Playaer's Avatar
Originally Posted by Kodiak
I use
Motor: 5 quarts Moble One Full Synthetic 15W50 Summer. 10W30 Winter.
Tranny: 3 quarts Redline Light Weight Shockproof
Rear Diff: OEM.
Transfer Case: OEM.
How many miles on your car? And how come you use OEM rear diff fluid, and not say Redline, with a little lsd fluid like BBYbruno said so the diff isnt as stiff
Old Aug 23, 2007 | 09:58 AM
Exciting News's Avatar
Originally Posted by Pure Playaer
Where as my motor oil wouldnt be the same as hers.
I can't imagine why that would be the case. In any event, I've always been fond of Amsoil 10W-30. I've never used anything other than Diaqueen/ Super Diaqueen for my drivetrain...
Old Aug 23, 2007 | 10:00 AM
because for a newer motor you use a thinner oil, as for older engines with more milage you use thicker fluid. (Pretty sure im correct here)
Old Aug 23, 2007 | 10:02 AM
rcheung's Avatar
Originally Posted by CRX2EVO
wtf is clutch fluid?
The clutch resevoir uses brake fluid and even shares the same reservoir with a divider between them . I just use regular autozone brake fluid.
Old Aug 23, 2007 | 10:04 AM
If she had 148K I'd maybe agree. 48K not so much. Up to you though...
Old Aug 23, 2007 | 10:06 AM
I see what you mean.
Thank you for explaining
We will probably not change them as they probably dont need to be changed
Old Aug 23, 2007 | 10:16 AM
Anyone else have any experience with:
Rear Diff: 1 quart Redline Heavy Shockproof w/1.0 ounce of Redline LSD Additive
And if someone could please help me.. On www.redlineoil.com show me what the LSD additive is?
Old Aug 23, 2007 | 10:20 AM
Mitchubishievo's Avatar
I do Amsoil everything bro...I suggested the same to you.
Old Aug 23, 2007 | 10:28 AM
Thanks Mitch, ill check out these products.. O yeah i gotta ask you something.. check your pms
Old Aug 23, 2007 | 10:43 AM
bump it
Old Aug 23, 2007 | 11:15 AM
Kodiak's Avatar
I have 42k miles on her and I choose to stick with OEM. I have the Quaife LSD and was told to use OEM fluid, since I have to buy it for the TC I use it in the rear also, makes it easier.
Old Aug 23, 2007 | 11:34 AM
so its between redline and OEM for most of the fluids.. im still not sure what we should do
Old Aug 23, 2007 | 11:53 AM
BBYBruno's Avatar
Redline Limited Slip Friction Modifier: http://www.redlineoil.com/products_g...5&categoryID=6
Just to let you know there are a lot of OEM
You hear of Redline horror stories because people use the wrong fluids in the wrong places. I've used Redline since the day I got my car with no problems. AMS and Shep recommended Redline products to me so that's what I use
Old Aug 23, 2007 | 12:00 PM
now if i go to mitsubishi and tell them i want 1 quart Redline Heavy Shockproof, and 1.0 ounce of Redline LSD Additive, will they be able to do it for me? and will they do it? like mix the fluids?
Old Aug 23, 2007 | 12:14 PM
Kodiak's Avatar
I would not trust the dealer to do anything on my car. Its really easy to do yourself. The fill plug for the TC is not in the most convenient location but still not that bad.
