got dynoed today! 4WS FTMFW!!
well i got mine used from a guy in here , so it wasnt that expencive also the fitment is great , i would recommend it if you're just gonna do al the bolt ons and not go pass 600hp
To the OP -- Nice job...Have you considered a full TBE? I wonder what you could have put down with a full TBE, o2 housing, and wga. Also, what did your boost peak at and what was it at 7500 rpm?
i think my power is right there with ppl. with a tbe since i was able to trap 112 with just the cutout, mbc and a flash.
im getting an o2 housing and a wg pretty soon, i also have a licp seating on the back of my car that im gonna install today. my boost spikes to 27psi and hold 20psi to red line
the boost will play more of a factor with torque than anything else. the car tapers the same after 5k so it doesnt make a difference when actually racing.
as far as daily driving a nice 400+ torque spike will put a huge smile on your face but Corrado takes care of the car and doesnt beat on it to push it.
Next parts we're both getting since we basically have the same exact setup is o2 housing, manifold and WGA.
With the WGA we're both hoping to hold couple more pounds to redline then running 30 pounds will definetly be worth it
Cheers!
Cheers!
specs
315mm X 500 X 100mm THICK
This is a direct bolt on utilizing your EVO'S stock piping,
Bar and plate core is 12.4" tall X 20" wide X 28 and 3.75 " thick
With over 1200 cfm flow at 1 psi pressure loss,
Over 85% more flow area than stock !!
Thats what the sight says.
