4g63 evo IV to IX
Old Aug 28, 2007 | 10:19 AM
akira2_03's Avatar
^ bump
Old Aug 29, 2007 | 12:41 PM
akira2_03's Avatar
^^bump
anyone know if the bell housing from the tranny's fit the same??
Old Nov 9, 2007 | 11:14 AM
downshift411's Avatar
evo 4/5/6 uses a smaller tranny. the evo 7+ use a much bigger tranny that will not fit the evo4-6 model due to it hitting the frame.
Old Nov 9, 2007 | 12:27 PM
crcain's Avatar
AFAIK as long as you are talking about a 5-spd box... they are all interchangeable between IV-IX. FWIW I've run an 8 gearbox and a 4 gearbox on my 6.
Also for the best pinout info go here:
http://www.lancerregister.com/showth...hreadid=142077
Old Nov 9, 2007 | 12:29 PM
crcain's Avatar
IV - VIII engines are very similar. Only difference I can recall is the thermostat housing where the two radiator hoses connect to. Both my friends with Evo 6's run 8 engines with 6 gearboxes. And the thermostat housings are interchangeable... just means you might need different length / bend radiator hoses to reach.
