HALLMAN MBC question
Old Sep 1, 2007 | 12:49 AM
W_evo8's Avatar
Old Sep 1, 2007 | 01:19 AM
Kdash106's Avatar
no you shouldn't have to disconnect the battery, what you need to do is take the soft spring out and put the hard one in.
Old Sep 1, 2007 | 01:37 AM
W_evo8's Avatar
put it heavy spring problem solved close thread
Old Sep 1, 2007 | 01:38 AM
W_evo8's Avatar
I did have fun tuning ti at 430 in the morning though haha no traffic nothing on the fuzz detector I'm at 23 psi 2-4th gear about 18 in first
Old Sep 1, 2007 | 02:19 AM
Kdash106's Avatar
are you tuned? if not i think u should lower the boost to 20 or lower.
Old Sep 1, 2007 | 05:39 AM
J-ROC's Avatar
I'm having the same issue.. my hallman MBC is turned up all the way also... and it only peaked at 20psi on 4th-6th gear. around 18-19psi 1st-3rd. I know to solve the problem is to replace the soft spring with the hard spring.. I was wondering if there's a place where i can buy the harder spring, since i accidently mis-placed somewhere. if anyone can help me out so I can get my car re-tuned at a higher boost. I want to boost atleast 23-25psi...
Originally Posted by W_evo8
Alright I hooked up my MBC to the wastegate line and tapped off the BOV, I can only lower the boost and when I turn it all the way up its the same when it was stock. I read that you should disconect the battery but its late and my alarm goes off if I do that so tomorrow I'll try that.
The max boost I have is 19-20psi with it turned all the way up. I have the soft spring in it right now.
Any useful suggestions are apriciated.
Old Sep 1, 2007 | 06:17 AM
suekie's Avatar
i would also know where to get the hard spring...best bet would prolly be to contact hallman and ask them if you can buy one straight from them.
Old Sep 1, 2007 | 06:48 AM
EMC2's Avatar
The light spring should work fine for 23-25 PSI. I have had no issues with mine. Not to sound like a jerk but ...is it hooked up correctly? Did you bypass the boost control solenoid when installing like Hallman recommends?
Old Sep 1, 2007 | 06:50 AM
Jakeg97's Avatar
http://www.boostcontroller.com/index...category%3D103
Old Sep 1, 2007 | 06:57 AM
suekie's Avatar
friggin saweet
Thanks JAKE!!!
Old Sep 1, 2007 | 07:21 AM
J-ROC's Avatar
NICE...... thanks man....
Old Sep 1, 2007 | 07:27 AM
J-ROC's Avatar
Yes it is hooked-up correctly, I followed the instructions from hallman, and one of the thread from EVOM. I changed all the stock vaccum hoses to make sure there's no restrictor. but still same results. MBC is turned all the way up, and its only peaking 20psi.... I might just try to get the heavy spring to see any difference before i go out and buy a new one....
Old Sep 1, 2007 | 08:51 AM
EMC2's Avatar
It was worth a shot...sometimes it the simple stuff we overlook. Wonder if my boost controller came with the heavy spring already installed. I didn't request it but stranger things than that have happened to me.
Old Sep 5, 2007 | 11:35 AM
Neuspeed06's Avatar
This is weird, because i have the FORGE MBC and it came with the hard spring and soft spring. With the soft spring in, i can only boost to 20psi. Whats weird is that when i put the hard spring in, it spikes to 30psi, then holds at about 26. Thats overboosting, and i took it out immediately. I have no clue why this happens.
Old Sep 5, 2007 | 11:58 AM
patty AT forge's Avatar
Did you reset the MBC to the softest setting or did you leave it set the same as with the soft spring?
