Lightest clutch pedal feel?
What aftermarket clutch will give the lightest or nearest to stock clutch pedal feel? It doesn't need to hold a ton of power. Basically stock power, but something that can be slipped, used for spirited drives, and launched a bit. For arguement sake, <450 horse.
Hey James. My clutch just began slipping today. I am trying to find a very gently used Exedy Twin Disk. They seem to be the most popular. Good for 500-600hp, stock like feel, and ppl always talk about 100+ drag launches with 30-40k miles on them. Used there 850-1100ish, and new one vendor on here has them at $1450.
exedy twins are popular for racing. There is no need for them on a wifey car. The fidanza clutch has a very soft pressure plate and the exedy single organic disc is pretty soft as well.
Through personal experience, you are looking for a Clutch Masters FX 300. It has the lightest Evo pedal pressure of any aftermarket clutch I have driven (that will hold bolt on power). As a side benefit, with the power you are talking about, the Kevlar disc will probably last longer than you want to keep the car.
BTW, no, I don't carry these. So I have nothing to "sell" you...
so your referring to this clutch?
http://www.titanmotorsports.com/clmast3.html
I saw 2 clutchmasters and just want to be sure.
Also, is this clutch like a on/off switch or does it slip easily for normal drivinig use?
tsitalon1
Jul 26, 2014 03:11 PM
initialDRacer
Mar 8, 2005 07:41 AM
