transmission problem..... i think?
Old Sep 3, 2007 | 09:35 PM
project VII's Avatar
maybe its the clutch and/or transmission? put in a new 'stock' clutch in about 3-4 months ago, but anyway no boost in 1 and 2 gear and 2-step launch. i think its the clutch but the real problem is 2 gear. while driving i would have it in 2gear and with just a touch of gas, the shift knob would kick me back to neutral (funny). 1,3,4, and 5 gear work fine except no boost with 1st. has this happen to anyone one or know how to treat this 'kicking me back to neutral thing'. it could be something simple, i don't know. i was planning on rebuilding tha tranny and new clutch. any help would be greatly appreciate. btw, its an 03evo with minor mods, intake, tbe, cams, mbc, 22psi on pump
Old Sep 4, 2007 | 07:34 AM
morning bump
Old Sep 4, 2007 | 07:44 AM
mac74's Avatar
Iy sounds exactly what your said its popping out of gear could be the presure plate was on bolted down tight? I wouold also checj the linkage arm on the tranny and make sure nothing is bumping into it when you are driving. They are not that stiff and if are accelerating maybe pushing on it.
Old Sep 4, 2007 | 07:53 AM
thanks mac74. ill get another clutch but my tranny is fine right? its really funny how the gear pop out only in 2gear and not the others
Old Sep 4, 2007 | 07:58 AM
mac74's Avatar
No problem, but just double check everthing before you get another clutch. Also if your modded we are you running the stock clutch?
Old Sep 4, 2007 | 08:16 AM
stock clutch yes. 330whp @ 22 psi pump. i was planning on the act hd. btw nice pass, is that on 9.8turbo and 02
Old Sep 4, 2007 | 08:28 AM
tweakdsm's Avatar
your tranny is fine, I would check linkage and if you're getting new clutch make sure you align it. I run ACT on mine for couple of months now and no problem.
Old Sep 4, 2007 | 08:31 AM
mac74's Avatar
Thanx the pass was on the stock 8 turbo with the 10.5 hotside. The ACT is the best IMO I loved it.
Old Sep 4, 2007 | 08:32 AM
thanks tweakdsm. ACT will do, hear alot of good stuff about them.
Old Sep 4, 2007 | 08:42 AM
pvporter1's Avatar
ok so mine just started popping out in 4th and 4th only. the only way to keep it from popping out is when shifting from 3rd to 4th i let the rev's come back down and let the clutch out with out hitting the gas but once i let the clutch all the way out i can mash the gas and it pulls like it always has. could this be the trans going bad or a bad synchro??????
Old Sep 4, 2007 | 09:03 AM
i need to know too
TurboTylerIX
21
Dec 19, 2017 11:16 AM
Legion418
15
Aug 28, 2015 06:31 PM
bnr34rb26dett
25
Jan 18, 2011 10:18 AM
Sn0w Man
Lancer Troubleshooting
Feb 10, 2010 01:48 PM
javip1986
Oct 29, 2009 10:51 AM
