Question for those spraying NOS
Old Sep 8, 2007 | 01:35 PM
  #46
supersupra's Avatar
Originally Posted by EvoTech
Some much stupidity in this thread. To answer the man's original question. Yes you can run the car on a nitrous map w/o spraying the car. The timing will be a little less probably (not much on a 50 shot), but the car will run fine. The fuel for the nitrous (wet) is added at the nozzle so this should not be an issue either. The tuner just needs to not "cheat" and fine tune your nitrous map via the injectors. If he does, your fuel map will be off when not running the n20. A 50 shot on a car with a stock map will probably not require any timing changes. If the car has already been flashed, it is a different story.
+1
Best answer so far.
Old Sep 8, 2007 | 02:58 PM
  #47
Owens Racing's Avatar
FWIW I had the similar set up on my Camaro. I had the delima of either tune N/A and risk it on nitrous or tune it nitrous friendly.
I really wanted to have the best of both worlds and being into building fast cars now for 14 years. I knew there is timing retarding equiptment. That can be activated via switch. Looked into a ignition box for extra spark and found Mallory makes a box that has a built in retard, window switch, boost retard, two step. Really nice piece. As for this thing working on an EVO.....I have no freaking clue. I am new to the EVOs actually have not bought mine yet. Will do so in the next two weeks.
If you can put a msd box or any type of ignition amplifier then I would think this would work.
Here is a link to it. http://www.malloryracing.com/Product...&minselection=
I will research this some for I plan to run a small shot on my EVO. Always loved a nitrous ****. lol
Old Sep 9, 2007 | 04:51 AM
  #48
ElCabo's Avatar
Originally Posted by rr06rs
Yeah TTP......ATTACK him!!! Get him with the "E" -TASER!!!! lol I swear....I love these internet bench rICERS. Warrtalon......I WISH you would come through FL so I could publicly BUST YOUR A$$! PLEASE let me know the next time you're in the SE!
Wow...nice internet threat...omgz0rs he's probably pissing himself right now b/c your so teh l33t!!!
Im pretty sure he doesn't like to have his *** "busted" though, he doesn't swing w/ the homos, but im sure he would be glad to come and own you on Sebring, n00b.
Old Sep 9, 2007 | 07:10 AM
  #49
4TUN8's Avatar
If you have not used nitrous you have no business giving advice about nitrous.
Old Sep 9, 2007 | 07:21 AM
  #50
sauce4u's Avatar
you guys are just too funny on here
Old Sep 9, 2007 | 11:52 AM
  #51
Jeff_Jeske's Avatar
He is getting heat because he asked this question in the wrong forum. We covered this very topic last week in the nitrous forum.
https://www.evolutionm.net/forums/sh...d.php?t=277189
Get the car tuned for whatever boost you want to run. Then tune the nitrous using the fuel and N20 jets. A 50 shot doesn't need any timing adjustments.
Many folks are running 26psi + 75 shot of sauce on 100 octane.
Old Sep 9, 2007 | 12:51 PM
  #52
EvoTech's Avatar
+1 a 50 shot on a stock ECU should require no changes. If it has been flshed with more timing, you may need to back it down a bit. This really does beling in the nitrous tuning section
Old Sep 11, 2007 | 05:23 PM
  #53
Cal Naughton Jr's Avatar
Thanks for all the answers thus far.
Here are some more questions for you:
1. What is the best way to spray NITROUS? (I won't be using the term NOS anymore unless I am refering to the company themself) I am wondering if I should spray when I need to with a button (like in 3rd or 4th if I need to) or if I should just have it set up with WOT and use it whenever I race.
2. If I set it to spray WOT, how will this affect my 2-step launch control? WOT while staging at the track with nitrous spraying, is that good? Or would it be something like a WOT setup, but I turn it on after I launch?
3. If my car is tuned for nitrous and it will be fine to run my nitrous(50-shot) map even when I am not spraying, if I were to spray and something malfunctioned with the Nitrous I would still be good right?
4. What is the best kit?
5. And a wet 50 shot on an Evo is actually more than that to the wheels, right?
Thanks
Old Sep 11, 2007 | 06:14 PM
  #54
xxNosTankxx's Avatar
I would figure out which kit you want first. Many people on this site seem to recommend NX(Nitrous Express). Then contact them with your questions about setup and all.
Old Sep 11, 2007 | 07:41 PM
  #55
+1 on NX
I like to use harrisspeedworks dot com these guys were some big help.
As well I have gotten some great prices from Nitro Dave.
Old Sep 11, 2007 | 07:52 PM
  #56
psphinx81's Avatar
1. use a WOT switch, when u get a kit there will be a arming switch u will have to arm first before u can spray. without this turned on u can go WOT all u want and not spray, once turned on when u go WOT it will spray.
2. to use your 2-step with the nitrous on and armed, get a window switch from www.dynotunenitrous.com this is an amazing failsafe to save your motor if u miss shift or overrev. u can lock out first gear and set the rpm range that u want the nitrous to spray.
3.running a 50 shot you shouldnt have to pull timing out, so ull be able to run the same map that u are when youre not spraying.
4. there are a lot of great kits out there, i use the harrisspeedworks kit and its an amazing piece, NX is good too.
5.yes when u spray a 50 shot ull see about a 75-80 whp increase
hope this helps, if u have anymore questions feel free to PM me
Old Sep 11, 2007 | 08:19 PM
  #57
TTP Engineering's Avatar
Originally Posted by Owens Racing
+1 on NX
Supporting the sponsoring evolutionm.net vendors specializing in the Lancer Evolution is always the best bet for any member.
Old Sep 12, 2007 | 06:01 AM
  #58
BURNALL_4's Avatar
+1^^^
Old Sep 12, 2007 | 06:16 AM
  #59
I understand your point. Is it a rule you can not support non sponsoring vendors, even I have used them for past three years for many different cars? Only one other guy did I respect when came to nitrous. He owned compucar back in the 90's. That dude was a guru too.
Not starting a fight just want to be sure I do not break the rules. Got to respect the forum.
As well, I have been into cars for many years (making them fast for 14 years)and when I make recommendations you can bet it is backed with my own experience and would not do so with out having the personal experience.
If I am breaking rules please say so and my posts will be deleted.
Again sorry was looking to help.
Old Sep 12, 2007 | 07:13 AM
  #60
Nesiop's Avatar
TTP I understand what you are saying but when asked about a specific kit/what someone is using I don't think it is wrong to mention it.
Granted I have never heard of it and would only recommend ZEX or NX.
