PCV and crankcase breather vent
When I look at my PCV, it look like it's two pieces. Is the actual PCV the L piece that goes into the valve cover, or the piece threaded INTO the L piece which is connected to the hose. Or is the PCV that entire assembely?
I'd like to use two or three inline fuel filters in the PCV system, but I don't want the plastic fuel filters to be pressurized. I want, like in DoctorEvo's illistration, the PCV between the intake manifold and oil catching "device" whatever it may be, a catch can, fuel filter, etc.
So again, so far, I've discover using inline fuel filter work WONDERS for breather to intake. Seriously, it's a really GREAT alternative to catch cans. about $7.50 every 5000 miles. So it equals the price of a catch cat in about 60-80K miles, not bad, especially if you're poor, like me
I'll report back after I relocate my PCV and use 2 fuel filter between the valve cover and PCV. Obviously, I'll be getting MUCH more oil, which is while I'll be using two filter back to back instead of just one
You did ..
your homework!!
I think that I've got a 'best of both worlds' solution.
It's modeled on the DC3 dual tank design.
...works best with a non-MAF configuration, but one could easily re-connect the outlet that goes to the mini K&N filter back to the intake pipe if you're metering air.
In this setup:
1) When there's a vacuum at the intake manifold, the factory PCV valve 'sucks' crankcase gasses from the factory location on the rear of the rocker cover. However, the crankcase gasses pass through an oil separator tank (filled with stainless steel mesh) before they reach the intake manifold. (This tank collects the bulk of the oil & condensation) ...the evacuated air is replaced by filtered, fresh air through the breather on the side of the rocker cover.
2) When there is positive pressure in the intake manifold (ie. On boost, or at WOT) the Factory PCV valve shuts. Any buildup in crankcase pressure is vented out the breather line. (the breather also passes through an oil separator)
So - bottom line is:
No buildup of gunk in the intake
Positive Ventilation of the Crankcase is maintained
No oily (octane reducing) vapours being introduced to the combustion chambers when "on boost".
In this setup:
The only thing that would need to be done to make it perfect for the Evo, as you said, don't run the K&N and have that pipe go to the intake nipple.
Very nice diagram.
aronjaskim
Oct 4, 2010 12:00 PM
vtluu
20
Aug 30, 2010 04:29 PM
BluEVOIX
Apr 3, 2007 11:52 PM
