+/- of dual disc clutch vs. single disc?
Old Jul 14, 2003 | 08:25 AM
loudogz's Avatar
ACTman
Do you have any clutch kit for the evo ? I want something stronger than stock but does not require to have hulk-power to press!
Thanks,
lou
Old Jul 14, 2003 | 08:40 AM
ACTman's Avatar
Originally posted by loudogz
ACTman
Thanks,
lou
Not quite yet. We have a couple protoype clutches out right now. The real problem is getting parts to work with from Exedy because it is a new car to the US market. It will be about four months before we get parts from Japan. It is not real practical for us to get parts from Mitsu. because of the cost and limited supply. I don't really want to fool with adding them to our lineup until we can get them from Exedy. However, Road Race Engineering doesn't seem to mind the trouble and is probably sending some clutches for us to modify so you can talk to them. The first prototype tests about 2950lb (stock is 2200lb). You will feel an increase on pedal effort but nothing drastic.
Old Jul 14, 2003 | 10:43 AM
Z1 Performance's Avatar
Dirk - yes both the Hyper Single and Dual disk are six puck spring hub, cerametallic disks
Adam
Old Jul 25, 2003 | 02:26 PM
ChillinEvolved's Avatar
In Timeout
so after all that reading... what clutch should i get! exedy twin disc? i need one that will hold up to 500 awhp.... exedy twin disc can right? also.. what do you mean by not being able to slip it as much... does that mean im going to struggle launching more? its hard enough as it is!
powerdriver
May 23, 2016 09:16 AM
evodude32
259
Aug 26, 2015 09:22 PM
romogst
Aug 22, 2013 06:57 AM
Don Q
Apr 23, 2012 02:08 PM
xh6
30
Dec 28, 2008 02:21 AM
