engine boggin @ full boost???
Old Sep 11, 2007 | 05:11 AM
AAEVO9's Avatar
this morning i punched @ 3rd gear and felt that at full boost (about 3800 rpm's) the car started to bogg back and forth.
I don't think this is a turbo problem because i can feel it spooling good, i think this might be more of an ignition or fuel problem????
anybody?????
Old Sep 11, 2007 | 05:16 AM
AAEVO9's Avatar
anybody?????
bump!
Old Sep 11, 2007 | 05:26 AM
AAEVO9's Avatar
Bump
Old Sep 11, 2007 | 06:01 AM
Freddy302's Avatar
See if you can get a fuel pressure gauge on it.. If it is holding boost.. It sounds like it is def a fuel or ignition issue...
how much boost are you running? Do you have a wide band 02 to see if it is getting lean?
Old Sep 11, 2007 | 06:10 AM
AAEVO9's Avatar
im running about 22 - 22.5 lbs of boost.
i just have not had the time to get a new tune for the higher lbs of boost since i got the HKS boost controller. prior to that i was tuned to run about 18-19 lbs of boost.
no wideband!
Old Sep 11, 2007 | 06:15 AM
saiyanzzrage's Avatar
plugs?
Old Sep 11, 2007 | 06:42 AM
600+hp's Avatar
It was plugs in mine. Regaped at .25 and everything works good now.
Old Sep 11, 2007 | 08:14 AM
Warrtalon's Avatar
You've had time to put on an HKS boost controller, but not time to get tuned for running an extra 3psi? You'll be lucky if you haven't damaged something in your motor.
Anyway, your description makes no sense. You need to explain it WAY better, because the engine can't "bog back and forth" when boosting. That's not even what bogging means. Please give us a detailed description of exactly what happens, at what boost, at what rpm, for how long, what noises it makes, which gears, etc etc.
Old Sep 11, 2007 | 09:29 AM
Charlie_B's Avatar
betcha its seeing some knock now, and going back and forth between the low/high octane maps.
Turn the boost down to stock levels, and see what it does.
Old Sep 11, 2007 | 09:34 AM
EvoG8r's Avatar
+1 turn down the boost. Had a similar issue when I tightened up all my IC pipes. I was suddenly running an extra 2 PSI and it would feel like it was bogging at full boost. I turned my boost down to the correct setting and the problem was gone.
Old Sep 11, 2007 | 09:37 AM
bluebyu36's Avatar
what a mess
Old Sep 11, 2007 | 10:18 AM
BURNALL_4's Avatar
tune it! that will fix it.
Old Sep 11, 2007 | 01:02 PM
travman's Avatar
Im going to guess its probably knocking and pulling timing which will make the car feel like it lost power....and as the knock decreases and timing is added back in it starts to feel like it picks back up.
Mauricio Evo IV
Dec 30, 2015 02:32 PM
phi79
Dec 10, 2011 05:05 AM
gentlyharsh
15
Oct 18, 2009 08:21 AM
evolution7jm
Jun 4, 2008 10:21 AM
mjb2118
27
Nov 22, 2006 07:45 AM
