overheating issues HELP
Old May 23, 2008 | 06:37 PM
evolution7jm's Avatar
was on my way to the track today driving really normal (slow) and my car started to run hot. the needle was a little above the half mark. got to the track did a few laps and it went closer to 3/4 but never higher, removed the thermostat and hard wired both fans, it helped a bit but when ever i was under full boost for a couple of laps it would creep up again. what do you think could be the problem?
Old May 23, 2008 | 06:39 PM
SpunEvoIX's Avatar
is your coolant to the top ...have any air pockets?
Old May 23, 2008 | 08:16 PM
mikiblueeyes's Avatar
dirty radiator would do it (from the inside) Had it flow tested at any rad shop.
Old May 24, 2008 | 06:48 PM
still not working
ok guys i am at the track and the race is in the morning. we changed the head gasket today because we found the head studs were loose, we also changed the radiator cap, the thermostat is working and the radiator has no leaks or clogs, the boost is now hitting fine and the radiator hose is no longer swelling but the car still overheats once i start driving hard, if i drive normal it does not heat up
Old Jun 4, 2008 | 10:21 AM
cnoevol's Avatar
bump. ever figure out the issue?
LCS
Feb 16, 2016 06:29 AM
Roen
Aug 13, 2013 03:22 PM
wake
15
Aug 3, 2009 06:36 PM
george3
Aug 31, 2008 07:38 PM
chrsevx
12
Apr 8, 2008 02:12 PM
