Keeping oil temp under control
Old Feb 7, 2016 | 11:15 PM
LCS's Avatar
LCS
Normaly my Evo's oil temp stays around 85 degrees celsius but when I get to the track it goes over 120 degrees before I finish the first lap.
I'm using a ducted setrab cooler a notch bigger than oil OEM cooler.
I would be more comfortable with temps around 110 degrees on the track.
Any help / thoughts?
Old Feb 7, 2016 | 11:32 PM
codgi's Avatar
Lots of discussion on this in this thread: https://www.evolutionm.net/forums/mo...ure-track.html
Old Feb 8, 2016 | 01:37 AM
m.al-hassawi's Avatar
i use to have the same problem, i got a Setrab oil cooler and was reach 120-130 i bought KOYO Radiator and it helped lowering my oil temp, now its between 100-110 Celsius
Old Feb 9, 2016 | 03:06 AM
LCS's Avatar
LCS
The only thing you changed was the oil cooler? No other mods on ducts, hoses, fans, etc?
Old Feb 10, 2016 | 03:20 AM
The oil cooler was already changed, and reaching 120-130 celsuis i change the coolant radiator I bought the koyo and oil temp when down
Old Feb 10, 2016 | 07:27 PM
LetsGetThisDone's Avatar
Means your water temps were very high too. This is why having a water temp gauge is important. The stock gauge is mostly an "idiot light" it stays in the same spot over a wide range of temps.
Old Feb 10, 2016 | 08:47 PM
Abacus's Avatar
I've tracked my car a few times on the stock radiator and stock oil cooler with no issues @450whp. I'm also using E85 so that helps alot.
Oil temp gets to 250-260*
A Ralliart 170* T stat is a good idea for open track use. The stock one opens at 180* but my car seemed to always run at 190+ Now its 170-180* for the most part.
I've used the 170* for a few years and the one downside I've found is the heater doesn't work that well. I'm in FL so thats not a big concern.
I'm also a fan of 20-50wt oil for hard track days on slicks.
Old Feb 16, 2016 | 06:29 AM
awdboosted's Avatar
I've also noticed that using the thicker 20-50wt oil (high zinc content, if possible) does keep the oil in the pan more. The catch can tends to fill up quicker when on a 5-30wt. Just an observation.
Mar 13, 2009 12:24 PM
nemosEVO
Mar 27, 2008 01:07 AM
edison
Sep 24, 2006 09:54 AM
