Help!!! Buschur fr3065 or fullrace?
Some think the tubular looks nicer. The horsepower will be a bit higher but the torque will suffer some.
Hey i have a 06 evo that is stock!!!!
I'm in IRAQ so all I can do is just buy parts
So I have been buying part and reading. Things I have bought so far are: 780 injectors, 272 cams and aem gears..tbe,mbc apr head studs turbo timer gauges. i wanted to know which turbo set up would give me great or pretty good spoolup and around 450 on pump....also i have thought about getting a aem ems but i have read under 500awhp i really dont need it.......
Pricing on our kits is $3490 which includes EVERYTHING to install, not just some of the pieces as with other kits that require you to supply your own. We also include our equal length tubular manifold at that price and offer a lifetime warranty on all of our parts. In addition, all of the T3 turbochargers in our lineup (50 trim, 57 trim, 58, 60, 61 and 67) will swap in without changing any of the other parts in the kit. Makes it easy to go bigger later without breaking the bank or tossing out half of the kit.
We are PROUD to support our military if you haven't already heard, so contact me directly for pricing
Tom
jarrod how much would it cost me to drop in the piston and rods? also i really will be using the car for a DD. i just love the power the car make for a fraction of the cost....!!!!!!!!!!!!!!thats so great....also i am in iraq so i would be able to call just email and pm's
Labor to do the drop in would end up being around $750.
Yes 400whp on pump isn't a problem even with a safe, conservative tune. How close to 450whp you make it will depend on the octane level of your pump gas, the tuner and your supporting mods
Tom
Tom
Our 3065 kit with our stages 1-4 and AEM EMS recently went 11.5 @ 118mph on 93 octane. That sounds around the numbers that you would be looking at roughly for what you're wanting to accomplish with the correct supporting mods.
I went 12.4 @120 with a 2.4 second 60' and a slipping clutch & easy shifting. She went from 86 to 120 in the back half. My alky kit is running the small squirter and running about 26psi of boost.
thanks for your interest in full-race products. there are a LOT of turbokit options out there, my advice is to do your research on all options so you can determine exactly which kit you works the best for what you are looking for.
for 450-500whp level, I recommend our twinscroll 30R turbo kit. This kit is going to spool very fast, make the broadest possible powerband and will be able to fit your needs for a long time. If you decided later on that you wanted more power, you could simply swap in a twinscroll 35R.
if you have any questions feel free to PM me. good luck!
Here's a picture of what we include:
