Help!! Water Leak! Help!!
Old Sep 20, 2007 | 02:00 PM
binhtran's Avatar
some please help me. i have a water leak as you can see in the picture I thought it might had been the water pump so i had changed it out but its still leaking. its like dripping
Old Sep 20, 2007 | 02:05 PM
kaonashi's Avatar
you shouldnt be leaking water there unless you have a crack in your block.
Old Sep 20, 2007 | 02:06 PM
binhtran's Avatar
omg are you serious???
Old Sep 20, 2007 | 02:07 PM
kaonashi's Avatar
well thats like on the part that attached to your block so i dont see how water could come from that at all. anyone else have an opinion?
Old Sep 20, 2007 | 02:10 PM
kaonashi's Avatar
This is mine see those holes most of the water journals are up top. Is it leaking where the bottom of the pen is in my pic?
Old Sep 20, 2007 | 02:13 PM
binhtran's Avatar
you see when i start up the car let it run for like 30 sec. turn it off u can see it start to drip like a drop at a time
Old Sep 20, 2007 | 02:14 PM
kaonashi's Avatar
turb the car on and get out and look for exsactly where its coming from
Old Sep 20, 2007 | 02:16 PM
Jedi_Gill's Avatar
FCOTM Winner
make sure your air conditioner is not turned on.. it might be condensation.
Old Sep 20, 2007 | 02:17 PM
kaonashi's Avatar
yeah i mean correct me if ime wrong but i dont think the oil pump should leak water is why im kind of thinking its not that.
Old Sep 20, 2007 | 02:24 PM
binhtran's Avatar
i did got another pic comming
Old Sep 20, 2007 | 02:26 PM
binhtran's Avatar
leaking behind that thing
tweakdsm's Avatar
you need to put the car on the lift use a hose with high pressure air, so everything looks dry...start the car with AC off, and look.
Old Sep 20, 2007 | 02:31 PM
binhtran's Avatar
i have the car jacked up and way sprayin air into the radiator cap and its start leaking where i showed you guys in the pic above
Old Sep 20, 2007 | 02:37 PM
binhtran's Avatar
from what we can see rite now its leaking from behind the motor mount braket we THINK it is
Old Sep 20, 2007 | 03:07 PM
kaonashi's Avatar
ok what your are looking at is parts of the motor mount braket that is connected to the tensoner.. if its leaking there then im sorry but you have a crackin your block look at my picture that is why i had to get a new block.
My advice, jack the engine up so that it will not fall and pull that mount off and see if water poors out.
