Brokern transfer case?
Old Sep 20, 2007 | 09:07 PM
midwestmonster's Avatar
I have an exedy triple disc clutch in the car and went to the track tuesday. On the first launch, I tried to slip it, but it almost felt like a dump of the clutch and i think I broke my transfer case. I don't hear any whining noise, but when I drive it and it gets up to speed, I hear a loud "clunking" noise. Is this the transfer case or could it be something in the transmission? It's an 03, so no acd. The trans shifts like butter, so I'm guessing it's the transfer case. Anyone have any experience with this? Thanks.
Old Sep 21, 2007 | 04:37 PM
Anyone?
Old Sep 21, 2007 | 04:42 PM
turboDan's Avatar
Drive the car in a parking lot at very slow speeds with windows down in a figure 8 and see if the noise gets worse and try to identify if noise is from front,back left side,right side or where transfer case is located..If it does it is more than likely broken spider gears but do not drive it much as it will do more damage than good.
Old Sep 21, 2007 | 07:07 PM
1NastyMR's Avatar
Its probably some type of internal part inside the transmission, from what i hear usally when you crack the case fluid will leak insanly and u hear the whining noise.
Old Sep 21, 2007 | 08:21 PM
The case isn't cracked and I tried driving it again today, but only heard the sound once or twice. It sounds like it's coming from the middle of the car. If the trans was broken, would I be able to shift well? The trans still shifts like butter......
It's a clunking noise, no whining.....If the spider gears were broke, what kind of sound would it make?
Old Sep 21, 2007 | 08:46 PM
How can I tell if I broker one of my axles?
Old Sep 21, 2007 | 08:59 PM
turboDan's Avatar
As simple as this sounds,By looking .Look where the axle goes into the hub,can also remove wheels and see if threaded part of axle that has the big nut/cotter pin on it is falling out of hub on outside.
Old Sep 21, 2007 | 09:08 PM
I will look this weekend. If one of the axles was broken, would it make a clunking noise sometimes or all the time? I only got the clunking noise randomly today driving it around the block trying to figure out what it was. Everyone says with a broken transfer case, you hear a loud whine. I don't hear that. The trans shifts smoothly still too. It would be great if it was just an axle....
Old Sep 21, 2007 | 10:09 PM
Mikael's Avatar
i've never shifted butter
Old Sep 21, 2007 | 10:13 PM
RoadSpike's Avatar
if you snapped the internal parts of the transfer case youd know immediately becuase it would sound horrific at any speed. If you damage the gearing they tend to howl.
You hear clunking which almost makes me want to point at motor mounts in a typical car but with an evo I just don't know. The motor and tranny mounts are pretty easy to visually inspect so I'd just put that only your list to visually go over when you put the car on some jacks.
Old Sep 21, 2007 | 10:36 PM
sauce4u's Avatar
but how is the clunking,cause i just broke my case like 3weeks ago,and it was clunking like it was loose when at slow speeds,then it just went
Old Sep 21, 2007 | 10:40 PM
rcheung's Avatar
Post a sound clip.
Old Sep 22, 2007 | 02:00 AM
Tvo's Avatar
Tvo
Simple test to see if your transfer case is broken is to jack the front of your car up and spin your front wheels by hand. If your wheel don't do the complete 360 freely and it gets stuck at one point of the turning, then your diff is broken. It happened to me and thanks to Shep Stage 2 transfer case, I'm a happier person now .
Old Sep 22, 2007 | 04:36 AM
94AWDcoupe's Avatar
you broke a tooth off spider gear. the clunk you here is that tooth being skipped. it will get worse very quickly.
Sheasta
Feb 6, 2016 08:29 AM
botemarc
15
Aug 6, 2015 01:21 PM
TigOLDBiTTies
Dec 3, 2012 06:03 AM
DEvoVIII
May 28, 2011 04:24 AM
CooleyKing
May 18, 2010 01:00 AM
