Help! Car suddenly went lean under WOT.
Old Sep 22, 2007 | 06:08 PM
NIevo's Avatar
I just recently got my 35R setup and 880 injectors installed and went to the track to do some tuning. Injectors were scaled correctly and the car was running great. First run I hit about 29lbs boost and everything seemed great but, still conservative. My AF/R's were from 10.8 down to 10.1 at redline and peak timing of 17*. I am using ECUflash and Evoscan along with a Zeitronix for tuning.
So next run I simply took .5 out on my fuel cause I wanted to adjust it slowly and left everything else the same. Well I launched and all of a sudden my ZAVT warning light came on for extreme EGT's temps and the car felt like crap. Got back and checked the logs and my AF/R's were high 15's tapering to low 15's at WOT!
What in the world could have happened? The car is fine at idle and part throttle but at WOT goes crazy lean. I added fuel and got it down to high 13's tapering to low 13's but I didnt get another run to keep testing. Something isn't right though because I shouldnt have to be adding so much fuel. My target AF/R's in ECUflash were low 9's just to get the 13 AF/R's. Where should I even start to look? I tested my meth injection and it tested fine, both the pressure and the test spray.
Old Sep 22, 2007 | 06:21 PM
Tuner@Swift's Avatar
Did the vacuum line pop of the fuel pressure regulator? Are fuel trims in check?
Old Sep 22, 2007 | 06:34 PM
jrsimon27's Avatar
check the vaccum line to on the fuel pressure regulator a friends evo with a gt30 had the same problem
Old Sep 22, 2007 | 09:34 PM
NIevo's Avatar
Wow, that was it, thanks guys
Old Sep 22, 2007 | 09:40 PM
4WS Tuning's Avatar
Cheers!
Old Sep 23, 2007 | 07:12 AM
Asmodeus6's Avatar
lol... zipties are your friend...
Old Sep 23, 2007 | 04:03 PM
mfr122887's Avatar
agreed
Old Sep 23, 2007 | 06:38 PM
NIevo's Avatar
Yep, zip-tied the crap out of it!
Old Sep 23, 2007 | 07:07 PM
596736's Avatar
Sean Ivey was talking about this line the other day in another thread. He sees it all the time he said
Old Sep 23, 2007 | 11:10 PM
Zeitronix's Avatar
Glad the Zeitronix Zt-2 and the ZAVT-1 warning box saved your engine from a total melt down!
Old Sep 24, 2007 | 04:04 PM
ROCK's Avatar
ZT-2 is all we use!
ROAD/RACE
Old Sep 24, 2007 | 04:42 PM
CrackerJackToy's Avatar
EVOM is a life saver, isnt it?
Old Sep 24, 2007 | 05:13 PM
Asmodeus6's Avatar
You should do yourself a favor and buy a pack of 100, and put them under your trunk mat. After you do every other line in the engine bay that sees pressure. And then if it has to come off for some reason cut it, and put a new one on. I'm the zip tie king lol... I always zip lines on and route wires/hoses away to keep things from becoming a problem. Saves so many headaches.
Sorry, I just had to laugh at you trying to tune around it. I've overthought a simple problem like that before too. Glad nothing terrible happened.
Old Sep 25, 2007 | 03:20 PM
Sean@Iveytune's Avatar
There you go.
And the cars will blow up because of this, I had one customer crack pistons on the highway when this line blew off so don't listen to them that it can't cause damage that line is mega important.
Check it out guys, please put zip ties!
Sean
Old Sep 25, 2007 | 03:24 PM
Spaceball 1's Avatar
I am on my way to the garage right now to ziptie that sucker.
asu11
E85 / Ethanol
44
Jul 17, 2015 01:31 AM
Faisalm
Mar 23, 2015 02:11 AM
sound77
May 13, 2012 06:53 AM
mac214
Sep 23, 2009 06:21 PM
Eurorcr
17
Jul 21, 2009 05:58 PM
