What turbo do I want? EVO9 or GREEN.
Old Sep 25, 2007 | 12:24 PM
Soon2BEVO's Avatar
Your list is awful.
Cams, definitely
Meth, definitely
VSR? Stock turbo... ehh $900-1000 for minimal gains.. 99% of people say not worth it
Cam gears? Definitely dont need those
Ignition? Ru serious?
Injectors? Not needed on any stock turbo setup, especially with meth
We can assume he will get a tune.
Your list is just a bunch of mods he doesnt need, espeically on the stock turbo (except 1/2).
I do agree he should max out bolt ons before looking at turbo upgrades but the mods you listed are certainly things he does not need and would not benefit from much if at all.
Old Sep 25, 2007 | 12:56 PM
yellowEVO21's Avatar
don't forget headstuds...if you're running meth and higher boost, i'd say this is a def.
Old Sep 25, 2007 | 01:11 PM
EVO8904's Avatar
Head studs are really not needed. I have been running 30psi since Feburary on stock head studs.
Old Sep 25, 2007 | 01:14 PM
Sir Lancelot's Avatar
Check my sig...20g9-5 I made 384whp/360tq on 93 pump @ 22psi without meth!!!
Old Sep 25, 2007 | 01:16 PM
justchil's Avatar
I made like 315ish on the BR dyno (mustang) on 93 oct 22psi conservative tune. With cams of course. This was with the 20G-9-5 also.
Old Sep 25, 2007 | 01:23 PM
Forrest Gump 9's Avatar
Off topic, have you run your car down the track with that same set-up? Just wondering what's your mph is? Thanks
Back to the original post. I don't believe in running meth. Too many horror story. So the best bet is the green. I know the green is an expensive investment, but it'll worth it in the long run.
Old Sep 25, 2007 | 01:31 PM
justchil's Avatar
No local 1/4 mile so all I've done is 1/8th mile for now.... I really can't remember my trap there either I'm thinking it was 90-92 in the 1/8th
Old Sep 25, 2007 | 02:44 PM
mplspilot's Avatar
Why would you want a 9 turbo? Get cams and meth and crank up the boost on your 8 first. And then get a bigger turbo, depending on what you want from the car you can either get a green and have a street monster, or skip green and step up to a bigger unit to run quick 1/4's.
Old Sep 25, 2007 | 02:58 PM
OKIX's Avatar
GO Green!!!
Old Sep 25, 2007 | 03:01 PM
Ph3n1x's Avatar
Originally Posted by APEX1
do the green and meth. 400whp is not enough
that will onyl give 450 or so....still not enough
Old Sep 25, 2007 | 03:18 PM
justchil's Avatar
I'm sticking with cams and a tune. Final answer lol
Old Sep 25, 2007 | 10:00 PM
Silver Knight's Avatar
If you're going to pay $500 for a 9 turbo try to get one with the install kit (outlet pipe and oil and water lines) with it. If not get it from one of the mitsubishi parts dealers on the forum here for around $75.
The answer to your dilema is all of the above like someone already said. Get the 9 add meth when you want more send off to the 9 to get FP'd. Just get cams.
And get those mirrors outta your sig.
Old Sep 25, 2007 | 10:03 PM
fromWRXtoEVO's Avatar
Evo green without a doubt.
Carlos
Old Sep 25, 2007 | 10:04 PM
APEX1's Avatar
Yeah Bro I think head studs were a fade.
Old Sep 25, 2007 | 10:07 PM
APEX1's Avatar
you are right!! Im thinking of a 35R with meth- maybe that will satisfy my butt dyno?! cuz to me thats the only thing that matters!
