HKS DownPipe Question for the Experienced
Old Sep 25, 2007 | 03:55 PM
jasonetc's Avatar
just bought a used HKS downpipe. I was told it was a 2.75", though when I measured it, seems to be only 2.5". It has a test pipe attached to it as well, and my plan is to retain the stock cat back.
I will be adding a fuel pump, and electronic boost control and getting it tuned, will the 2.5" downpipe hinder the performance I am trying to accomplish with these mods, or should I return it and look for a 3". I like the idea of the 2.75" allowing for a little more torque at lower rpms, but I don't want to be wasting my money on a 2.5" if it's not worth it.
Thanks
Old Sep 25, 2007 | 03:59 PM
zbomb's Avatar
I would have to say that if you re keeping the stock cat back 2.75 aint gonna make a difference. Your restriction will be in the cat back, not the down pipe.
P.S. I would seriously consider getting rid of the stock cat back. Any particular reason you are stuck on having it?
Old Sep 25, 2007 | 04:13 PM
jasonetc's Avatar
I figured I could make up the diff with the test pipe. I also want to keep it quiet.
Old Sep 25, 2007 | 06:57 PM
Mr. Evo IX's Avatar
I think you'll get significant gains with a catless system, dp, and stock exhaust, and still be nice and quiet. Better than putting just a catback on with the cat and stock dp.
Old Sep 25, 2007 | 07:04 PM
EJEvo's Avatar
I believe what everyone is saying is that you need to remove all the significant restrictions before you'll see much advantage. Changing just one of these (dp/cat/stock cat-back) will free up some, but if you keep a restriction downstream of the DP, you won't see any real gains out of a DP change. By changing all of them you'll see much greater improvements.
Old Sep 25, 2007 | 10:35 PM
jasonetc's Avatar
I know, that's what I am trying to do, the setup I bought is a dp and test pipe, so along with the stock system, those two alone should free up alot of the restriction and I will still have a pretty quiet setup.
I was just wondering if anyone had anything bad to say about the HKS 2.5" DP if I didn't plan on changing out the catback?
Old Sep 25, 2007 | 10:47 PM
DJmarkymark's Avatar
2.5 is better than stock, but it wont help much because the exhaust gets restricted when going back to the stock diameter
id recommend you get a stealth catback like a tanabe exhaust or an exhaust with multiple resonators
i had a 3inch tbe including a buschur o2 housing, and i just recently sold my catback
im now using the stock catback, and i can feel a definite restriction
Old Sep 26, 2007 | 06:15 AM
Brian's Avatar
DP Should be fine, I had one that I never used as I had issues test fitting it with acd clearance.
As far as the stock catback is concerned I believe FIMotorsports on here cut low 11's while he was still running it.
Old Sep 26, 2007 | 07:31 AM
jasonetc's Avatar
Well, I appreciate all of the responses. I will go ahead with the install, because as for now, I am not looking to build a 500hp monster. If it feels like a cat back system would help, then maybe I will look into a quiet set up. I also know some selling some HKS cams, 263 and 273 degree setups for a couple of bills. Would these be worth the money for a street set up before the tune if I am simply adding a fuel pump, DP, TestPipe, and electronic boost controller? I am not very well educated on cams
thanks
Old Sep 26, 2007 | 07:50 AM
evo150's Avatar
its 2.5 inches only at the flange (allows the downpipe to be bolted to the stock cat), the rest of the downpipe is 2.75
tsmithr1
Nov 26, 2006 06:56 PM
Oracle1
Apr 17, 2006 04:00 PM
Johnny Boy
27
Apr 12, 2006 12:40 AM
Joe250
Aug 10, 2005 07:29 PM
BlueEvo04
Oct 20, 2004 11:11 PM
