How much power on stock injectors?
Old Sep 27, 2007 | 01:45 PM
dsm25psi's Avatar
I wanted to know how much power can i get and how much boost i can run with walbro pump and stock injectors?
I'm putting in a gt30r turbo kit and wanted to know if i run about 20-22psi will the stock injectos will be ok with the pump to support the fuel system?
Old Sep 27, 2007 | 01:58 PM
RyuEvoIX's Avatar
Yes.
Old Sep 27, 2007 | 02:27 PM
dsm25psi's Avatar
Thanks
Old Sep 27, 2007 | 02:33 PM
Ted B's Avatar
I don't think I'd make that recommendation. Depending upon the rest of the configuration, the stock injectors are far more likely to be over the limit than under. Quite frankly, if one can't overrun the factory injectors with a GT3076R and pump fuel, he isn't getting his money's worth out of the turbo kit.
Better to be safe than sorry, especially when we're dealing with <$300.
Old Sep 27, 2007 | 02:54 PM
1.8tfanatic's Avatar
Yea
Yea you caN FIND A NICE SET OF USED INJECTORS ON HERE IN THE CLASSIFIED SECTION FOR A PRETTY RESONABLE PRICE. I PICKED UP DENSO 770'S FOR I BELIEVE 145 SHIPPED OR SOMETHING LIKE THAT!
Old Sep 27, 2007 | 05:41 PM
Asmodeus6's Avatar
What will they technically flow enough to support HP wise in a #.
Maybe that will make it easier to see where that threshold is.
Old Sep 27, 2007 | 07:38 PM
GTVEVO's Avatar
The threshold is about 20-21 psi at 7k to get to 100% on the stock injectors. This was on my car with cams and all other supporting upgrades. I would keep things below that until you upgrade injectors.
Old Sep 27, 2007 | 08:27 PM
Ted B's Avatar
The stock injectors are 550cc/min, or roughly 52 lb/hr.
Given a BSFC of 0.55 lb/hr/lb, that works out to ~380 bhp (not whp) before they reach their rated capacity. Injectors aren't rated at 100% IDC, so there is some cushion (15-20%), but any setup capable of 400whp on either 93 octane or race gasoline will demand an injector upgrade.
Old Sep 28, 2007 | 04:41 AM
adamhw's Avatar
or an alky pump for extra fuel
Old Sep 28, 2007 | 04:46 AM
recompile's Avatar
Buy some PTE 780's, you'll need them.
Old Sep 28, 2007 | 10:25 AM
dsm25psi's Avatar
i just dint want to get really bad mpg with big injectors since i drive my car a lot.
Old Sep 28, 2007 | 10:30 AM
4WS Tuning's Avatar
run meth injection and youll be fine
Old Sep 28, 2007 | 10:38 AM
meckert's Avatar
Your going to need to do some homework:
Max HP= (injector mass flow rate) x( # of injectors)x( duty cycle)/ Brake specific Fuel consumption..
This is the formula--No, I didn't throw in your numbers... and you will need to make some determinations for whats being asked here..there maybe a calculator on line...
onyxwagon
E85 / Ethanol
Jul 10, 2012 06:18 PM
dsm25psi
62
May 3, 2010 05:09 PM
george3
34
Oct 15, 2008 06:52 AM
David Buschur
74
Jan 17, 2007 07:09 AM
crazy_evo414
14
Aug 18, 2003 04:35 PM
