Highest whp 2.0L EVO on 91?
Old Sep 28, 2007 | 12:23 PM
Jim in Tucson's Avatar
OK, I’m calling out the highest whp EVO's on straight 91.
Who all is running 91 octane and putting done over 400 whp? Or close? What are your mods? Particularly your turbo and cams. Thanks much!
On this thread so far we have:
squeekr, 424whp/301trq, 37R, 21 psi, BR Mustang dyno
SuPeRNeT, 374whp/320trq, 20G-lt, 20 psi, Helix 272/272, Apexi intake, Ported/coated E.M., TurboXs I/C, AMS LICP, ETS UICP, LPI 3in TBE, TTP 02, Sun Hyper voltage, Walbro, Pte 880cc's, S.M.A.R.T Xede/flash , Wideband, Knock Box, Greddy E-01 Boost controller
WOT, 363whp/364trq, 16g TME, 272i/264@-2/0, AEM ems, 65mm TB, 3" O2 & TBE, FMIC, LICP, test pipe, oem injectors, Yimi Motorsports DynoJet
In addition, I've found elsewhere on Evom:
Silvercar, corrected 407whp/353trq, uncorrected 326whp/283trq, 3071R, VIII GSR
evoracer32, 402whp, AMS GT3076, HKS 272, AEM ems, Tunning Tech's DynoJet
EFIxMR, 375whp/285trq, GT35R, Gruppe-S Mustang Dyno
Alan678, 361whp/333trq, EVOGreen, 23psi, 18lb W/G Actuator, HKS 272i/272e Cams, 850cc Inj, MBC, Megan O2, K&N Drop-in, Greddy V-Spec I/C & LICP, APS DV, AMS TBE, Testpipe, Walbro 255lph F/P, Vishnu Cam Gears (-4i/-1e), ARP Headstuds
If these members are still around, please update your info. A couple of those need some explaining. Should I be listing corrected or uncorrected? I'd like to see PSI on each of these? Not all have cams listed?
Old Sep 28, 2007 | 12:38 PM
LIL EVOL's Avatar
Would like to know this too and how to safely get there.
Old Sep 28, 2007 | 01:20 PM
Aby@MIL.SPEC's Avatar
i made 360/360 on a dj while on 91 octane using a 16g.
check out the links below. my mods should be in my sig too.
Old Sep 28, 2007 | 01:24 PM
34Turbo's Avatar
You may make 400 on a large turbo but it would have crazy low torque.
Old Sep 28, 2007 | 01:26 PM
brokenRS's Avatar
i would also like to know.
wot,
accordin to your dyno with the cams, the 272/264 combo has more power over the 280's?
Old Sep 28, 2007 | 01:28 PM
xchoirboy's Avatar
You can search around norcalevo.net home of the 91Oct. I would check the power mods forum
http://www.norcalevo.net/index.php?o...action=search2
Old Sep 28, 2007 | 01:31 PM
SuPeRNeT's Avatar
Heres mine 374 hp 320 tq.. low TQ is from my boost control issues.. 20 psi
Old Sep 28, 2007 | 02:21 PM
Originally Posted by tien
wot,
your just looking @ the spikes. if you take the spikes out, the 272i/264 combo made ~350 whp
the 280's flat out accelerated the car much quicker than the 272i/264 combo, despite what the dyno said.
Old Sep 28, 2007 | 02:45 PM
mrdecrypter's Avatar
im @ 315whp, 306tq on 91oct. definitely not the highest, but im in 91 oct club hahaha
Old Sep 28, 2007 | 05:12 PM
SickSilverNLow's Avatar
I am in Oregon and we use 92 octane which is pretty crappy too..........let me know if you want my numbers.
Old Sep 28, 2007 | 05:58 PM
Got_Lag?'s Avatar
Here's the thread... not all 2.0l but you get the idea...
https://www.evolutionm.net/forums/sh...ight=king+pump
Old Sep 28, 2007 | 09:13 PM
Thanks for the lead. I'll follow up on that. However, most forums won't allow searching for a two character word like "91".
Old Sep 28, 2007 | 09:16 PM
Was that an VIII turbo or an IX turbo?
Old Sep 28, 2007 | 09:18 PM
Sig says E85. Is the graph on E85 or on 91? I'm confused. Thanks!
Old Sep 28, 2007 | 09:42 PM
Thanks for the link. I had not been able to find that for some reason. I read the entire thread and here are the members on straight 91:
If these members are still around, perhaps they can update their info. I'll add them to the first post. A couple of those need some explaining. Should I be listing corrected or uncorrected? I'd like to see PSI on each of these? Not all have cams listed?
