How MucH boost on a GT35R w/ Meth & 93oct?
Old Sep 30, 2007 | 08:39 PM
evobob8's Avatar
I have ....
2.3 Stroker
SBR Stage 6 head
Ams Gt35r
Ams Meth inj. Kit
880cc inj.
gsc 272/272
Old Oct 7, 2007 | 08:41 AM
evobob8's Avatar
bump
Old Oct 7, 2007 | 08:49 AM
EVOLVEU's Avatar
bigger injetors first, then it depends. 30psi daily, 36 at the track.
Old Oct 7, 2007 | 08:52 AM
evobob8's Avatar
Ams told me they wont flash anything over the 880cc. Im running on the stock ecu cause of emissions.
Old Oct 7, 2007 | 08:59 AM
psphinx81's Avatar
im sure ull be able to run 30 psi
Old Oct 7, 2007 | 09:07 AM
evobob8's Avatar
Thumbs down
my only thing is I had a stock block and i put on the 35r,meth kit,880s and i laid down 485whp on the dyno. I lasted about 4000 mi till my bottom end gave out . I check my meth kit when the motor went and everything is still functioning correctly so i dont know if 485 was just too much 4 the bottom end or maybe the meth blew me up. Im in between a rock and a hard place. My question is should i keep the meth now that i built the stroker and the head?
Old Oct 7, 2007 | 09:14 AM
bluebyu36's Avatar
wow that alot diffrent then your first question
Old Oct 7, 2007 | 09:16 AM
Pure Playaer's Avatar
with built motor go for like 30-35 psi
Old Oct 7, 2007 | 09:18 AM
Nesiop's Avatar
485 Is def. not too much for stock bottom end. No where close.
Old Oct 7, 2007 | 09:19 AM
evobob8's Avatar
My question shouldnt be how much boost it should be........ Should i keep the meth injection. I just need a bunch of input cause i am awaiting tuning.
Old Oct 7, 2007 | 09:21 AM
Rez90's Avatar
i have virtually the same setup as you do.
34psi. everyday.....and when it's cold out.......it boosts higher.......
Party on wheels.
Old Oct 7, 2007 | 09:22 AM
evo_8_u's Avatar
I put down 592 on my stock bottom end, an ran it for about 30k miles......
take it for a grain of salt
Old Oct 7, 2007 | 09:30 AM
evobob8's Avatar
when i hear this it leads me to beleive it might have been the meth then.
Old Oct 7, 2007 | 09:31 AM
cij911's Avatar
I would check your Meth setup and make sure you have a great failsafe (e.g. ZT2)...If you run modest boost (on just pump gas), you should have gone with a different turbo selection IMHO...
Old Oct 7, 2007 | 09:34 AM
VIPGarage's Avatar
first off the 880's will do you just fine. The 1000's are just a pain to tune so stay away from them unless you ABSOLUTELY push the setup to the max.....
So if I understand this correctly you are now on a built head and stroker? If that's the case it all depends on your hopes and dreams.
If you want to be in the 500hp club you need meth bro. You can make good power from a 35R without high boost and meth. For example a local VIII has our 35R kit on it and makes 458whp at 22psi. just 93 octane, no meth and a stock head. Needless to say you should be able to make a bit more power with a good flowing head.
I would recommend you wait to run the meth until you get tuned so you have lower risk involved. Sounds like you probably broke your piggy bank on this last build.
