How MucH boost on a GT35R w/ Meth & 93oct?
Old Oct 8, 2007 | 12:50 AM
  #31
haseeb's Avatar
hey ,ive got the same set up which im goin to install in a month or so ,plz tell me that my tuner has told me that we will be running 2.2 bar boost .
so the question is that ive got 880 cc injecters ....r they gona b f9 for 2.2 bar boost .
Old Oct 8, 2007 | 05:37 AM
  #32
C6C6CH3vo's Avatar
Originally Posted by evobob8
my only thing is I had a stock block and i put on the 35r,meth kit,880s and i laid down 485whp on the dyno. I lasted about 4000 mi till my bottom end gave out .
What kind of oil were you using?
What RPM did you rev too and was it with the OEM torque to yield rod bolts?
Perhaps too much turbo for running methanol without safeguards also.
Old Oct 8, 2007 | 07:04 AM
  #33
SwiftEVO's Avatar
I had a 35R with a stroker motor and put down 538 on 28psi with meth and 92 oct.
Old Oct 9, 2007 | 09:02 PM
  #34
evobob8's Avatar
the most the motor was reved to was 7500. Yes it was the oem torque yeild. The oil used was mobil 1 sythetic. When the rod gave the rod bolts were fine. the rod snapped on the middle of the beam.
Old Oct 14, 2007 | 08:50 AM
  #35
evobob8's Avatar
bump
Ang Wen Yan
348
Jan 8, 2017 11:50 PM
gmac03
Jun 5, 2014 07:37 PM
mandy1
Oct 4, 2007 05:52 PM
Lucas English
41
Jun 11, 2007 01:24 PM
o.e.boost
Nov 26, 2006 04:18 AM
