Recomended Spark plug gap for 1.5 bar
Old Jul 9, 2003 | 09:17 AM
boostedwrx's Avatar
I know for DSM's its .028 but I remember Shiv saying something like .026 on the EVO's............
Can anyone chime in? I plan on replacing my stockers with another set of stockers this afternoon.... I think I may have fauled one during my dyno tune.
FYI~ The Stealerships want $30 per plug NGK # IGR7AG Iridium or whatever... gheyness..
Old Jul 9, 2003 | 09:34 AM
Shawn Glass's Avatar
Conicelli Mistubishi has them for $18 each, stil expensive but cheaper than $30. www.partznet.com.
Shawn
Old Jul 9, 2003 | 09:45 AM
bigd's Avatar
Boosted,
What sort of problems you having that make you think you fouled a plug?
Old Jul 9, 2003 | 09:55 AM
boostedwrx's Avatar
getting either a bad misfire or fuel cut in 4th gear upon full boost at 4000rpm.
Same thing in 5th...
Im kinda leaning towards Fuel cut.. im pushing 1.5 bar, and my guage is kinda ghey..
Old Jul 9, 2003 | 04:56 PM
Shahul X's Avatar
What Denso Plug would let us run cooler... I think its .0028
-Shahul
Old Jul 9, 2003 | 06:37 PM
umiami80's Avatar
I ran ..20, do it in some BPR 7ES plugs, they are one stage colder and resist detonation, get them. Cost nothing in comparison. NGK BPR 7ES and gapped to .20 to run 20+PSI
Old Jul 10, 2003 | 09:56 PM
boostedwrx's Avatar
.020????
manual says .024 - .026, i just looked it up (duh, dont know why i didnt beforehand!)
Should i gap the 7ES's to that? I ran them on my GST too! Will they work for the EVO as well???
Old Jul 11, 2003 | 03:57 AM
Shahul X's Avatar
NGK BPR 7ES plugs, gap them to 2 not 28? those are copper plugs?
-Shahul
Old Jul 11, 2003 | 06:32 AM
boostedwrx's Avatar
bump ditty bump bump
Old Sep 16, 2003 | 03:47 PM
mitsuorder's Avatar
bump, oriely and carquest list the evos as having an f'ing gap of 44? well i'm changing mine out right now and will go 5 thousandths over that which the stockers are gapped, tuners out there what do you suggest gapping a NGK BPR7ES at for say a hair under 1.5 bar around 21psi???? help would greatly be appreciated
Old Sep 16, 2003 | 06:04 PM
AvatarOfWar's Avatar
I'm getting the same backfire under the same circumstance, and it's progressively getting worse. Talked to AMS, they recommended the NGK BPR 7ES gapped to .028, which I'll be putting in tomorrow night.
Old Sep 16, 2003 | 07:41 PM
2Cool's Avatar
I prefer the NGK coppers, as I Densos seem very fragile to any form of detonation, with their ceramic breaking very easily. Thats an expensive break. So I use NGKs and change them fairly often, as they are comparatively cheap. I normally gap at .028"
Old Sep 16, 2003 | 07:42 PM
mitsuorder's Avatar
ok, gapped my NGK BPR7ES's at about 31 today, car is ******** some ***, man did my stock plugs look nasty, all that running rich from the factory I guess, just realized I totally forgot to apply the antisieze stuff that o'riely gave me to the threads. should I go back and apply that stuff? is it bad to back the plugs out after the copper crush washers have already been compressed? with an aluminum head will I be ok without the antisieze stuff till the next time I do my plugs? thanks for any answers in advance!
Old Sep 17, 2003 | 08:57 AM
QuantumEVO's Avatar
Ok to remove and reinstall. I never use antisieze.
1.5 is too much boost on stock turbo even with 93 (which is the minimum octane for that level). You aren't making any more power at that level. 20 psi is a good level for 93 octane with FMIC, exhaust, etc.
.030 is too much gap. .020 is too little. One will cause misfires, etc and the other will not make as much power as you could.
umiami80
Aug 3, 2016 09:34 AM
jb988
Mar 22, 2016 01:13 PM
Gamble
May 30, 2015 06:38 AM
Adam J
Dec 16, 2006 11:00 AM
