Turbo kit next in power after green?
Thanks for insight fellas, learned alot so far. I guess it just depends on supporting mods, which turbo will best perform on current parts.. According to you guys,.. 3076>3065>50trim>green>gt30?(in some cases?) Might just save and go with the 3076, and eventually rebuild engine in time, for optimum power. I wont mind lag.
Will check out what tom at ets has to offer.
Will check out what tom at ets has to offer. Let me type them out for you and clear this up a pinch.
GT3071R (Gt series cartridge ball bearing turbo)
GT3076R
FP3065 (GT30- center section modified compressor wheel and turbine housing)
AKA GT3082R or GT3040R (all the same, just 3065 is FP's naming system, and ^)
Lets do the order again too.
FP3065>GT3076~big 50trim>GT3071~ GREEN ~ small 50trim> IX 20g> VIII 16g
The GREEN, small 50 trim, and GT3071 are all in similar territory. Close enough to call even, leaving out specific setup details. Different rates of spool, and small variance in power between them. But you could make each's numbers with the other with a good setup. Out of these the GREEN makes the most sense. Power, vs, simplicity, vs spool. It wins in most cases.
But because no two cars are alike, setups, tuning... there's a reasonable amount of give and take even inside that fairly general guideline.
your not going to get a full spool at 4000 with a 3065 or a 3076. sorry. maybe a 50 trim and a green.
sounds to me like a 50 trim would be perfect. its about the same as a green, maybe flow a touch more.
but honestly all this lag talk is so over rated. once u get used to it, u will love it.
I had full boost at 3500 in 4th gear in my car 3700 in 3rd, this was a 2.3 + 3076 (.83A/R) and a real manifold.
Scorke
GT30, is a few of the turbo's you listed. lol!
GT3076R
GT3076R
The 30R's are sweet turbo's, people who either autocross or just enjoy low RPM/ and especially tq are insane on the street.
My 3076+2.3 made 480 ft lbs of tq at 4800 rpms on c16 at 30 psi. That is more than most 2.0 35R's make.
Scorke
Id say that comparo is accurate. I don't know how much more if any a 3071 will make over a green, a 3076 definately will.
Scorke
Scorke
Man! I would love that WTQ at 4800 rpms! Talk about white nuckle
Scorke
Scorke
I think maybe with race gas or a larger AR turbine housing the 3071 could beat the GREEN. But probably wouldn't be worth it in comparison to the simplicity and response of the GREEN. You'd be better off taking the 3076, in a smaller AR and still making more power. But that's how this stuff is. Its never cut and dry. Which is why your overall setup is so important.
Scorke the 2.3l & 3076 must have just been a fu**ing animal.
Sounds like its alot of fun.
Well OP, hopefully that gives you a better guideline to weigh your decision. I know I tried to lay it out as clearly as possible. I've been here before a few times trying to decide what exactly I wanted. And its not always easy.
PS: GO STEELERS!
Maybe Im thinking of another.. but the one I saw was different mods and different boost. I had a great comparo with a full bolt on, cammed IX with a 3076 on meth (who went 11.3@125) vs my green setup on meth and it was a dead heat to over 125mph, yet I was ahead at the end. Much different.
A 3076 will spank a green on racegas I believe.
If your going to spend 4-5k on a turbo kit who cant afford some expensive gas to get another 150 or so whp out of it for times when you want a really fast car.
Scorke
