HTA GT35R Dyno results right here!
Old Oct 6, 2007 | 02:08 PM
evo L's Avatar
Originally Posted by LT1runner
Well folks I have to say that this turbo is the $hit. It did better than I expected. As you can see on the dyno sheets, it was done on a dyno dynamic dyno. So if it where on a DynoJet, I may have gotten around 485+/- 5HP. And yes on 21.5 psi.
Thanks to Andrew and Bruce at Dyno4mance for fighting with the MAFT Pro box with a touch of ECU flash to smooth things out. Andrew said I made the most HP on pump gas ever on his Dyno.
and now the ****.
Video to follow!
yup they sure are there when you quote him, but not when its posts... weird... great numbers though!!
Old Oct 6, 2007 | 02:15 PM
DarksideEng's Avatar
Nice name
Old Oct 6, 2007 | 02:19 PM
LT1runner's Avatar
Dyno Vid
Here's a video of the last run.
http://s234.photobucket.com/albums/e...t=Dyno_vid.flv
By the way, with this turbo, I'll be able to autocross this bad boy with now problem or worry of lag.
Ditch that 30R and 35R and get that HTA!
Old Oct 6, 2007 | 02:26 PM
mchuang's Avatar
Holy**** look at that torque curve 300tq also at around 4100rpms that is crazy..other gt35s are at about 600rpms later..are you on a 2.0 or 2.3. Man I want that turbo!!! Who the hell needs twinscroll when you have that turbo.
Old Oct 6, 2007 | 02:29 PM
thatguy's Avatar
He has a 2.3
Old Oct 6, 2007 | 07:09 PM
Jasil's Avatar
Even with a 2.3 you can see it spools faster than a regular 35R.
Old Oct 6, 2007 | 09:16 PM
david@maxum-tec's Avatar
wow!! i really dig this turbo!!!
just out of curiosity, what helped you make the decision to use the ams manifold? not that they are bad cuz they are definitely one of the best out there but just curious why you chose them over others?
Old Oct 7, 2007 | 07:38 AM
Migsubishi's Avatar
Very nice man and looks like it wanted to keep making power past where you let out. Just wondering why didn't they take it to 8k? One last question, what cams are you using?
Old Oct 7, 2007 | 07:45 AM
LT1runner's Avatar
I already had an AMS kit with the 3076 on it. So I just retained it. I didn't feel like spending more money on something I already had. All I had to do was get a .63 housing, coat it and put it on the turbo so I could continue to use the AMS kit.
I'm using HKS 280s. That's where Andrew and Bruce of Dyno4mance was comfortable with. Basically you don't want your car on the edge all the time. Especailly with staright 93. This was just a pump gas run. Next time I'll do a meth tune. Maybe in 2 weeks.
Old Oct 7, 2007 | 07:51 AM
Migsubishi's Avatar
280's, now now your power makes more sense, man your engine breaths really well to want to keep making power over 7500. Thats awsome, I'm very happy for you, keep at it I'll be watching
Old Oct 7, 2007 | 07:56 AM
Rez90's Avatar
2.3ltr @21psi on 93 oct. This result may not be good enough for you, but it's a good start for me. Andrew dyno reads alittle low, so I'm told, so if that disappointed you, then oh well.
Relax man......
i wasn't insinuating anything or trying to tell you that i wasn't impressed with my question about your motor.....
I was just looking for clarification on your setup because i wasn't sure and i failed to realize from the original post........
Old Oct 7, 2007 | 08:05 AM
LT1runner's Avatar
Originally Posted by Rez90
Relax man......
No biggie. I guess I came across the wrong way on that response. It's cool essa
Old Oct 7, 2007 | 09:49 AM
rr06rs's Avatar
Man, I really want to see this thing in twinscroll form! awesome numbers man!
Old Oct 7, 2007 | 09:53 AM
Spazpilot's Avatar
LT1runner
Weren't you running a AMS kit and had the HTA modded to fit the AMS turbine house or am I thinking of someone else on this forum?
Old Oct 7, 2007 | 12:03 PM
Migsubishi's Avatar
Originally Posted by Spazpilot
LT1runner
Your thinking of someone else. You don't have to mold anything and he explained everything real well. Picture a normal 35r bolted to an AMS manifold, its just that easy. The physical size of the turbo is not changed just a compressor wheel and compressor housing. It will bolt up to every and anything an AMS/PTE/Buschur etc 35r would bolt up to.
