HTA GT35R Dyno results right here!
http://good-times.webshots.com/photo...38095062fUTHYp
There are other pics of the kit there if you want to check them out.
WOW
93 octane
awesome results....kinda have me thinking about ditching the fp-grn.
can you list all your mods please....this way it will give people the recipe for some amazing results!
93 octane
2.3 ltr
Manley stroker rods
wiesco stroker pistons
4G64 crank
Head ported
HKS 280s
1mm oversized ferra valves
1000cc injtrs.
AMS turbo w/HTA 35R with .63 exhaust housing (ported)
coated header, exhaust housing, and O2 housing
TRE tranny w/exedy twin disk clutch
tuned with ECU flash and MAFT Pro in speed density form.
Manley stroker rods
4G64 crank
Head ported
HKS 280s
1000cc injtrs.
Here is a link the FP's write up I'll let Robert's words do the talking Scorke.
Repeated dyno testing and thousands of miles of street punishment have shown how much faster spooling the HTA is compared to the normal 35R. Midrange and bottom end torque which are usually dismal in regular .82 A/R GT35r kit cars are DRAMATICALLY improved with HTA compressor technology!
And you come up with this how considering this was the purpose of the turbo to begin with more power under the curve with similiar/same top end. Do we need to post Buschur's original dyno sheet again showing the 50ft/lb TQ improvement and improved spool?
http://store.forcedperformance.net/m..._Code=Turbo-FP
Because you lose so little in top end while getting the most out of the midrange/spool up.
Jasil the HTA 35R is a 35R with a different compressor wheel on it. Altering the turbine would of had a much greater effect on spool up, the HTA was created to make more power out of a 35R frame turbo, that is all.
Scorke
You can see the main difference between our graphs Jasil et al is after full boost is already made. At 5k I am making 360 whp at 5k he is making 330, I gain about 80 after that where he gains about 110, the HTA 35R compaired to a normal 35R will be very similar with more power up top, everywhere else shouldnt be very effected.
p.s. I know our dynos read very different and your car is making considerably more power than mine but the shapes of the graphs tells the story about how similar/dissimilar the setups are.
Scorke
Scorke
Scorke
Scorke
Now I know a 30R will spool quicker, but it truly "feels" like it doesn't. Like I said I just got off of the 30R two weeks ago. So it's not like I've forgotten.
I know you've probably forgotten more about cars\evos than I'll ever know, but your statement doesn't make sense to me. You make a point and have disproved it in the same post. If you dynoed on a dyno dynamics, and the curve was the same, then I'd understand. Due to the dynojet sheet, who knows if your car would produce the same curve. Yes those curves are similar, but the difference in the dynos themselves is the biggest thing against your argument to me. Comment further, because I'm always up for learning something. Seeing as I just got off of the 30R, it "feels" like it comes on almost as fast, but very smooth at the same time. Driving this car almost feels like a 30R until you realize how fast you're going in the same distance verses the 30R.
I had a 30R too, I think the 35R feels slower honestly. To me the place you feel the difference between the 30R and 35R is 4-7k in 3rd gear and higher. If you were to tip in to the throttle below 4k in a 30R vs the 35R I would have to assume that if both cars were going equal speeds it would take a good few seconds or a gear or two for the 35R to catch up.
My 30r was gone more than 2 weeks, about 3-4 months ago but I know what your saying,I completely agree with how similar it feels to the 30R, however I think you and I both forget exactly how much low end/mid range tq we gave up for the higher numbers up top.
Great numbers btw, car must haulllll ***!
Scorke
FP's turbo compaired to a regular .82 A/R 35R might improve tq and spool up considerably, but compaired to a .63 A/R 35R will still spool slower. Ask Buschur why they tested vs a .82 A/R 35R instead of a .63, and ask the rest of the evo aftermarket why 99 percent of people running 35R kits run the small hotside.
If I already had a kit that used the four bolt pattern on the .82, then I would have kept that. So are you saying it would have spooled slower if I kept the .82, or it does spool slower due to the .63?
Remember full boost is nothing but a target boost setting to me. So full boost is 21psi on pump gas. So full boost(21psi) around 4000 would be slower than a standard 35R using a .63 hotside?
