362whp/363.77wtq pump gas Evo IX!
Old Oct 11, 2007 | 08:01 PM
  #121
EVIL_EVO_VIII's Avatar
Originally Posted by SHhhhh
Does your fuel pump smoke?
what do u mean if it smokes?
Old Oct 11, 2007 | 08:08 PM
  #122
DrivelineSales's Avatar
wow very impressive ... Great numbers for the amount of mods
Old Oct 11, 2007 | 08:32 PM
  #123
1QYK9's Avatar
Originally Posted by nightwalker
Dyno numbers shouldn't be worn like a badge of honor, but used as a tool. Which it really is. People in the know, know that HP differs from dyno to dyno, even the same ones.
What we should really be looking at are quarter mile times. Because if you laid down 400awhp, and can't run as fast as the guy who put down 370, then that's a problem.
That's not a fair, or accurate, statement at all. There are a number of factors which impact drag racing times (1/8 or 1/4 mile), to include the following:
1. Driver (the single most important factor)
2. Track conditions (probably the second most important factor)
3. Torque (even if both cars are making 300hp and weigh the same, if one car is making say 50ft-lbs more than the other it will be quicker in drag racing)
4. Weight (obvious)
5. Gearing (a car with better gearing and requiring less shifting is going to have an advantage in drag racing
Need I say more?
Old Oct 11, 2007 | 08:47 PM
  #124
nightwalker's Avatar
Actually it is. Because I love it when guys sit around and brag about their dyno numbers (which have variances in torque, spool, power under the curve, different dyno, etc.)
Then when it actually comes down to it, their car doesn't perform. Isn't that what we're all after in then end? ...or are we just tuning and spending all this money to wave our dyno charts around?
And it's nobody's fault if you can't drive.
Old Oct 11, 2007 | 08:53 PM
  #125
1QYK9's Avatar
Actually it is.
If that is what you want to believe, then so be it. Who am I to change your mind?
Old Oct 11, 2007 | 09:21 PM
  #126
kouzman's Avatar
well if your car makes power then even if you are an average driver the car will perform...
for example... at around 305whp dyno dynamics uncorrected with 3500 pounds racing weight...
my very first run ever at the dragstrip with the evo and very first drag run ever on a proper dragstrip...
60ft - 2.148
1/8 - 8.39
1/8 speed - 85
1/4 - 12.81
1/4 speed - 113
fourth pass ever i managed
60ft - 1.723
1/8 - 7.8
1/8 speed - 87
1/4 - 12.12
1/4 speed - 114.2
even if you are not an excellent driver and you just do a decent pass the car will show what kind of power it has...
Old Oct 12, 2007 | 05:08 AM
  #127
BoOsTinGEVO190's Avatar
I do agree mph count I ran
60ft 1.8
1/4 12.6@109.xx very hot day
60ft 2.2
1/4 13.1@111.58 fup on my lunch twice Cool day though
Old Oct 12, 2007 | 05:18 AM
  #128
SHhhhh's Avatar
Does it smoke Mar-lboro's?
Good numbers by the way. Could you tell a difference after the FMIC, UICP, and intake?
Old Oct 12, 2007 | 05:40 AM
  #129
Blazing VIII's Avatar
I agree, as I stated the same thing. A dyno is a safe, controlled tuning devise, the track shows your true power, no matter how you drive.
Old Oct 12, 2007 | 02:50 PM
  #130
.. Yes it was a very NOTICEABLE difference
Old Nov 10, 2007 | 04:23 AM
  #131
SpeeDeviL's Avatar
WOW great #
one question
did you upgrade the springs and retainers or you used the stock one's??
Old Nov 10, 2007 | 08:12 AM
  #132
Originally Posted by SpeeDeviL
WOW great #
one question
Stock ones
Old Nov 10, 2007 | 10:54 PM
  #133
SpeeDeviL's Avatar
Do you think you'll get more power if you upgrade the springs and retianers??
Old Nov 10, 2007 | 11:00 PM
  #134
red evo8's Avatar
whats your exhaust cam gear set at?
Old Nov 10, 2007 | 11:10 PM
  #135
SixOneNine's Avatar
Stock injectors right?
