The Ultimate Evo 8/9 Transmission Failure Survey
I was curious, so I whipped up the following survey. Does it warrant a sticky?
http://www.esurveyspro.com/Survey.as...c-faff66e5e8b4
It's purpose is to stratify failures across models, as well as give some statistical insight to failures as a whole and is not intended to isolate 6spd MR failures (although that is covered).
I tried to ask questions that were more or less relevant and plan on having some professional statisticians here at work give us a somewhat edumacated breakdown.
thanks.. I think it probably sets a cookie in your browser... If you did one in IE and one in Firefox that should work, or if you clear out your cookies.
For everyone else.. PLEASE include build/mfg date. thats a pretty interesting piece of information
The thing about the clutch line pill is that it's there as a safety measure, but people remove to "help" with launches. Doing this is kind of like taking knee pads off of the drivetrain. It's much easier to damage something on a launch after doing this.
The funny thing is that with a slight adjustment of your technique, you can launch just as well with the pill in place. I've personally pulled a 1.62" 60' on the stock clutch and stock Advans with the pill in place. I average 1.72" or so.
With DRs or slicks the pill might cause too much slip, but not many people here with DD Evos run at the track with sticky tires.
I took it off on my VIII, so I was always scaried Id drop it to fast and break something, which in turn would make me drop it to slow and burn a lot.
On my IX, I left it in. Now i just drop and let the restrictor do the work. I have gotten consistent 1.7-1.8 60's
Ok, about 35 responses so far.. lots of 03s and 06 MRs.. need more samples people some RS and 05MRs
some interesting tidbits
42% have experienced some form of transmission failure
only 1 failure at the track, 3 at the dragstrip
no respondents are running a tranny cooler
c'mon folks.. theres a few thousand of you guys.. can someone sticky this so we could get more data? a sample size of 35 isn't going to be all that accurate.
