vacuum loss at idle after LICP/UICP install
I just finished up installing a Nisei LICP and ETS UICP. Before this I had -20PSI of vacuum at idle, no I'm right around -17. Is that normal?
I really took my time, double and triple checked all the fittings. I hear no leaks and the car seems to run fine, I haven't went out and ran it WOT yet because I have to leave in a few hours on a 300 mile trip and if something did come loose on a WOT run, I wouldn't have time to fix it, so I figure I'll just take it easy until I get back.
It already has an ETS FMIC, my vacuum did not change when that was installed.
Things I did at the same time: change spark plugs, cleaned HKS RS intake, changed the oil, installed KW V3's and Tein plates.
Any ideas here, or is it normal to loose a little vacuum?
Do I need to disconnect the battery and let things reset?
R. Burgundy
Jun 5, 2014 11:58 AM
Anubis18
May 9, 2013 07:17 PM
GinNBoost
Mar 26, 2010 09:53 PM
no way
