Car idle problem *HELP*
Old Oct 13, 2007 | 08:59 PM
xLaNcErEvOx's Avatar
Okay i just put back on my valve cover after getting it powdercoated and i also re-routed my throttle cable under the strut bar. Now i started the car and it idled fine till it was fully warmed up and right after i gave it a little gas the idle was stumble as if it were choking. It wouldnt stop doing it and almost shuts off. Whats my problem?
Old Oct 13, 2007 | 09:02 PM
KcEvil8's Avatar
maybe vacuum leak somewhere
Old Oct 13, 2007 | 09:27 PM
could it be anything else?
Old Oct 13, 2007 | 10:27 PM
BOOSTEZ's Avatar
I have this problem when I'm on a hill and give it gas and then release the gas and press down on the clutch. I have to be rolling and putting just a small load on the car like going over a speed bump. I don't put on the brakes so it's not the brake booster putting a load on the car. It will stall and almost die and if I have the A/C on, it will die. It only does this on a steep incline.
I'm suspecting it could be the MAF being inaccurate at an angle, or something fuel related.
If a vaccum leak exists, wouldn't you find it with low boost and flaky idle ALL the time?
-M
Old Oct 13, 2007 | 11:15 PM
LoBoost's Avatar
i had the same problem when i rerouted my throttle cable.i put it back and the problem went away.
Old Oct 14, 2007 | 12:16 AM
GT35REVO8's Avatar
check all boost lines...i took mine off last nite to fix a crack and re paint it,and today i was idling high sputtering,come to find out i forgot to hook up one of the lines,it was late.just recheck everything
Old Oct 14, 2007 | 12:20 AM
ctbz860's Avatar
going to check mine too, i got that same problem, but geez, i'll wait for the sun to come up first
Old Oct 28, 2007 | 02:31 AM
nasty8evo's Avatar
shazam: throttle cable put it back!
Old Oct 28, 2007 | 10:45 AM
barneyb's Avatar
Flaky idle speed stepper motor?
