20GLT (fpgreen) dyno sheet from this weekend at Buschur Racing
Old Oct 16, 2007 | 08:44 PM
  #46
volkskid's Avatar
nice figs you got, wat's the housing size you running on the turbo? 9.8cm2 or 10.5cm2?
Old Oct 17, 2007 | 12:16 AM
  #47
RazorLab's Avatar
Originally Posted by WOT
what octane is this? fuel vendor?
thanks
VP Import
Maximum power and torque in small displacement, high RPM, all motor, turbocharged or nitrous sport compact applications. Makes 5% more power than C16 and similar nonoxygenated fuels. Works well under high temperatures due to mechanical heat.
• Color: Clear
• Motor Octane: 120+
• Specific Gravity: .744 at 60° F
http://www.vpracingfuels.com/vp_01_fuels.html#leaded
Fun stuff.
Old Oct 17, 2007 | 06:34 AM
  #48
OKIX's Avatar
Originally Posted by speed club p.r.
evo 9 rs with apexi coloivers, mini batery kit, small brakes,15 wheels,no back seats,intake,pipes,exhaust... 3150lbs??? I dont belive that weight!!!
No backseat??? I dont have one in this picture, but I have the backseat in it. Along with a full welded in 5pt roll bar!
Old Oct 17, 2007 | 06:37 AM
  #49
OKIX's Avatar
its the 10.5
Old Oct 17, 2007 | 07:17 AM
  #50
9sec9's Avatar
Good job Razorlab. Thanks for the post and info.
Old Oct 17, 2007 | 07:18 AM
  #51
Paul Nelson's Avatar
Very clean
Old Oct 17, 2007 | 07:20 AM
  #52
OKIX's Avatar
Thanks ifarted2!
*edit* your screen name still cracks me up!
Old Oct 17, 2007 | 07:26 AM
  #53
Rcebowl's Avatar
Hey OKIX,
Who did your rollcage? It looks great!
Old Oct 17, 2007 | 07:27 AM
  #54
Thanks ifarted2!
Chrome Moly? looks like it.
Old Oct 17, 2007 | 07:33 AM
  #55
OKIX's Avatar
Originally Posted by Rcebowl
Hey OKIX,
it was done by Tony Palo of T1racedevlopement in Dallas, Texas.
You are correct
Old Oct 17, 2007 | 07:35 AM
  #56
9sec9's Avatar
speedclubpr, Do they teach math in Puerto Rico? If not, I'll add it up for you:
Stock car weighs 3219 lbs (no fuel)
5 Gallons of fuel is ~ 35 lbs
Driver weighs 130 lbs
Helmet, Harness, logging equip 15 lbs
5 Point Roll Bar/ Plates ~ 75 lbs (conservative)
Alky kit, 2 qts fluid, pump ~ 7 lbs
Total Car Weight BEFORE reductions: 3481 lbs
*forgot OKIX stereo system (yes, I know) speakers, unit, wire add 20 lbs min.
Remember, FULL INTERIOR, BACK SEAT and ALL!! Pics were taken when roll bar was built, not when it was raced, since Back seat HAD TO BE INSTALLED for the race.
Weight reduction: Coil overs saved 60 lbs
Battery saves 25 lbs
Wheels used (15X7 CE 28N and QTP's vs stock setup) saves 10 lbs per 40lbs total
Brakes (Wilwoods) saves 60 lbs (at most)
Center Engine Mount saves 3.6 lbs
Rear Moustache saves 12.6 lbs
Spare removed saves 37 lbs
Misc engine piping/plastic 15 lbs
*forgot 3" exhaust (can't remember reduction, but Buschur Racing has it)
Total Weight Savings: 253 lbs
Total weight - savings = 3227 lbs (I'm sure I missed a little of the reductions, somewhere, but I still have 50-60 lbs to go, before I even reach my quoted 3175-3180. There you have it. Simple math. I hope you understand and aren't too biased to believe that THERE ARE FAST CARS OUTSIDE OF PUERTO RICO. We also have to live by NHRA and sanctioning body rules. I don't think we can get away with using motorcycle slicks on cars, or nitrous in stock classes. This is my rebuttal to your " I don't believe it" comment. Do the math.
Old Oct 17, 2007 | 07:41 AM
  #57
9sec9's Avatar
One more math puzzler for you. Horsepower, torque, weight, et. Proven dyno numbers, proven et's. Somehow, that equates to the weight posted. Believe it.
Old Oct 17, 2007 | 09:15 AM
  #58
mrboostt05's Avatar
i believe thats crazy i bet people are looking at this thread and jumping off the big turbo dd bandwagon right now props to you
Old Oct 17, 2007 | 09:33 AM
  #59
9sec9's Avatar
This car is by no means the 'norm' for a Green. But it does show what it's potential is. I firmly believe that a daily driver can run 10.5s on the green, IF the motor is built properly. The OKIX engine was MAXED on the stock block when combined with the RPM's needed to run 10.8's. Engine is being built at Buschur's but will remain a 2.0, stock MAF, stock Ecu, same cams, same turbo. Head will have some light work and stock size SS valves and springs. Daniel Buschur will also be Buschwacking the tranny to an Evo VIII 4th gear. Clutch is remaining the same, but we are going ahead and changing it out to a new one, Exedy twin-disc Cerametallic HD unit. With about 35-40 fairly hard passes, no need to take chances when the opportunity to change it exists.
Old Oct 17, 2007 | 10:28 AM
  #60
Nuked's Avatar
Congrats man, nice setup, nice times. Def making me rethink my 3065 plans!
SQ
