exedy twin disc...i hate it
Old Oct 16, 2007 | 07:12 PM
mandy1's Avatar
after 1000 miles and drop the trans 4 times because tob popout,i will move to quarter master products.exedy already send me some parts to repair cliping problem,but all my friends have same isssue with no luck with parts exedy send them including addition of 4 wave springs in the pressure plate,so i will not take a chance again.if anyone beleive in this clutch make me an offer,can send pics.
Old Oct 16, 2007 | 07:22 PM
94AWDcoupe's Avatar
TOB popping out is an install issue. If you dont stab it perfectly centered it is very easy to bend the clip setup. Then it can pop out. I beg you to find me one post where a new car had a TOB pop out. The factory clip is identical to what comes on the exedy twin. It is very hard to install a tranny without bending the clip prongs. Especially when you install on the ground at home.
Old Oct 16, 2007 | 07:41 PM
mandy1's Avatar
i have install oem clutches and ACT without problem,but this exedy is bringing me crazy.
Old Oct 16, 2007 | 08:20 PM
WickedWhiteRS's Avatar
The clutch is mint i have on in my car. I installed it myself and had minor issues with the wedge collar. I wont judge a clutch until you drive on it when it is together properly.
Old Oct 17, 2007 | 11:24 PM
evo L's Avatar
never had a problem with exedy, been installing there multiplate cluteches for years...
Old Oct 18, 2007 | 05:40 AM
duracell55's Avatar
Never had any problems with my Exedy twin either, looks like is an install issue.
I have over 20K miles and over 100+ track passes on it
Old Nov 3, 2007 | 09:54 PM
MrMejia's Avatar
I think you should rethink who installs your clutch. If your the one I think you should be patient and make sure everything is perfect next time you tackle it. When I did it at my house I find that droping the whole centermember and leaving the power steering hanging or proped on something is the best way to put the tranny back on. I had the engine tilted downward in a 45 degree angle and then put the tranny on and then lifted the engine and tranny together so that it would slide in like butter and have someone screw the tranny mounts in once its level. It's alot easier said than done but you get the point.
STM Tuned
Evo 'For Sale' Engine Internals and Drivetrain
92
Oct 25, 2017 08:39 AM
CT9A PR
Dec 4, 2014 03:51 PM
Chris@nolimitmotors
21
Nov 29, 2012 10:50 AM
Scottr126
Dec 9, 2008 10:01 AM
GCT9A
Apr 12, 2006 10:37 PM
