Hollow out HFC?
I already have installed a mechanical CEL fix for the HFC. Having a test pipe won't cause me to fail emmission, but it would cause me to fail state inspection.
Full Function, when I said "It's free" I ment hollowing out the cat, as opposed to buying a test pipe... but I see where you're coming from with the profit. Reason I don't buy a test pipe is because I have the bushur TBE and the HFC is flanged on one end and is slip fit on the other and uses a band clamp. I can't use just ANY test pipe.
I just figured if I can take my HFC out and gut it and throw it back on it 10 minutes and still easily pass state inspection, rather than buying a test pipe and having to switch it out for state inspection, the hollow HFC would be the way to go.
My one question was is there going to be any HUGE performance differance in a hollow HFC and test pipe?
Some guys gut the HFC and then weld a straight through piece of 3" pipe inside the hollowed out Cat carcass. The theory being that a gutted cat is more disruptive of exhaust gas flow due to its non constant internal diameter.
I personally don't think that there would be any measurable difference betwee a gutted HFC and a test pipe. I ran a gutted Random Techologies Cat on my Turbo Buick for years. Then I gutted the Evo's stock Cat as well. I say do it!
Thanks for the info guys. MUCH appriciated
I understand it will not flow as well as a test pipe... but worse than being in it's original condition??? I thought the honey comb was basically like a "filter" for exhaust fumes... not really there to prevent turbulance.
I'd think it would flow better, of course not as well as a test pipe, but atleast better.
Kreeker
13
Oct 22, 2015 10:17 AM
vivac2
Feb 18, 2010 10:46 PM
antics22
Sep 15, 2008 07:30 AM
