p0335 and p0340 help
Old Oct 31, 2007 | 04:31 PM
evilevo22's Avatar
do you have to take off both belts to see the crank sensor?
whats the easiest way to get to the sensor
Old Oct 31, 2007 | 05:38 PM
bigric09's Avatar
no...
the easiest way to get to the sensor is to take off the serpentine belt, remove the 2 pulleys that are covering the lower timing belt cover, then remove the lower cover itself. you may also have to take off the tensioner pulley for the serpentine belt, i dont remember. The sensor sits inside just off to the right side of the crank sprocket... You do not have to take off your timing belt to see it... and if you are careful you can actually replace the sensor without taking off the timing belt. Now here is the *** pain, to replace the sensor and send it thru the stock location, you have to take off the power steering pump and the bracket holding it in place... or you can cut the new sensor and resolder it when you are done running the wire. I have done it both ways and they both work just fine.
Old Nov 1, 2007 | 03:42 PM
evilevo22's Avatar
ok thanks for the help
Old Nov 7, 2007 | 05:08 PM
evilevo22's Avatar
what way is the right way to install the sensor i dont wanna put it in upside down
Old Nov 7, 2007 | 05:14 PM
bigric09's Avatar
if you put it in upside down, the crank blade will not spin thru the sensor.... the blade should some spin thru the sensor so the tab should be on the inside.
Old Nov 14, 2007 | 07:45 PM
evilevo22's Avatar
i just started up the car with the new sensor in and the codes are still there. I earased them and started the car up again and they came back.
What should i do now ive replaced both the cam and crank sensors .
Old Nov 14, 2007 | 08:20 PM
G20's Avatar
G20
did you done anything to the car prior to the codes?
Old Nov 14, 2007 | 09:30 PM
evilevo22's Avatar
i installed cams and injectors
Old Nov 14, 2007 | 09:46 PM
bigric09's Avatar
by chance did you install the cam sensor incorrectly.
Old Nov 15, 2007 | 09:29 AM
G20's Avatar
G20
make sure your cam gears are line up to the mark perfectly. Verify the cam sensor install as well. The problem is likely somewhere in the cams installation process.
Old Nov 15, 2007 | 04:40 PM
evilevo22's Avatar
the timing has been checked twice by a shop and the car has been inspected numerous times with no mechanical error.
could the cam positions sensor be installed incorectly.
the codes are camshaft sensor A- bank 1 circut malfunction, and crank sensor A circut malfunction
what else do i have to replace
Old Nov 21, 2007 | 05:39 PM
evilevo22's Avatar
bump
Old Nov 22, 2007 | 02:15 AM
evilevo22's Avatar
bump
Old Nov 26, 2007 | 01:15 PM
evilevo22's Avatar
what else could cause these codes
Old Nov 28, 2007 | 02:06 AM
evilevo22's Avatar
was searching the internet and found this the signal genorater what exactly does this do ive never heard of it
http://www.tfelectronics.com.au/PageFiles/products.html
