new car hole in my intake manifold help!!!
Old Oct 26, 2007 | 12:57 PM
  #31
RSGuy's Avatar
return the car to stock
Old Oct 26, 2007 | 05:19 PM
  #32
Asmodeus6's Avatar
That manifold got cast on a Friday.
Old Oct 26, 2007 | 05:31 PM
  #33
tripperfx3's Avatar
DO NOT GO TO ALLISON MITSU!!! They are complete idiots!!! My GF's friend took her car there and they couldnt find out why it was throwing a CEL! DEE-DEE DEE!!! Hook up a scan tool and read it! Then they told me they had to "dig" for the code, which yet again all you have to do is read the screen on the scanner! The code was for a TPS and i told them to replace the TPS... They did and guess what!? The car works!!!
If you must go there contact Slowtruevo here on the forums first and ask him what to do. Hes Allison's Evo tech.
Old Oct 26, 2007 | 05:34 PM
  #34
TTP Engineering's Avatar
Take it off and weld it for $10.
Old Oct 26, 2007 | 05:59 PM
  #35
AlwaysinBoost's Avatar
if the dealer won't make it right, instead of taking it off, throw some JB weld on that bad boy and call it a day.
Old Oct 26, 2007 | 06:07 PM
  #36
CrackerJackToy's Avatar
Factory Defect, get a new one.
Old Oct 26, 2007 | 06:16 PM
  #37
dubbleugly01's Avatar
Here is a pic of a perfectly good manifold with no leaks.
Are you referring to the casting hole between #3 and #4 runner? You're pic is such a close up, it's hard to tell what part of the manifold it is. If this is the same hole you have, you're fine.
Old Oct 26, 2007 | 06:27 PM
  #38
baggedtaco's Avatar
thats def not what the whole in his looks like.. it does look like the hole is at the end of a weld
Old Oct 26, 2007 | 06:31 PM
  #39
the stock manifold is cast, there are no welds. shadows and angles in a photo can cause things to appear different that what they are. If it's a weld, then there is definitely a problem. The op either needs to get a better picture for us to see, or be able to tell the difference between casting slag and a weld.
Old Oct 27, 2007 | 01:48 PM
  #40
~EVILEVO~'s Avatar
wow this thread really scared the crap out of me because after reading the first post i went and checked my car and sure enough i found a hole!
But, thanks to dubbleugly01, and pointing out the fact that there is a hole from the factory i feel much better. however mine still has most of the excess cast, so its only about the size of this guys.
Old Oct 27, 2007 | 01:55 PM
  #41
TheLab's Avatar
guys, there are NO welds on a factory OE cast manifold.
Old Oct 27, 2007 | 02:25 PM
  #42
Aby@MIL.SPEC's Avatar
the stock manifold is cast, there are no welds..
my oem cylinder head is casted too & there is a welded section on the inside near the #1 cam cap!! Yeah, i have seen 3 cylinder heads welded up like mine, when doing cam installs.
the pic is crap, however there looks to be a weld, but jeez, this is aluminum, the weld should be huge. the weld in a pic looks as if it were a tig weld!?
Old Oct 27, 2007 | 02:28 PM
  #43
saiyanzzrage's Avatar
Originally Posted by evox7
My evo 9 have been dying on cold start ups lately. So I decided to pull the air intake apart and take a look and check all the conections. As im doing so I look over to the intake manifold and find a small hole, a little smaller than an eraser head on what appers to be the number3 cyclinder. The car has turbo back exhaust and an itake thats it. Only 14k on it too. What should I do? Go to the dealership? will he honor my warranty? Get a aftermarket manifold that is better and hope I didnt get a lot of **** in the cylinders? Help me out here guys. Thanks
i have an intake manifold with throttle body from my evo ix for sale, all sensors included, perfectly fine and working (NO HOLES!)
8500 miles on it, PM if interested
Old Oct 27, 2007 | 06:17 PM
  #44
the hole this guy has, at least what it looks like in the pic he posted is right by the throttle cable. If you look at the nice cleam OEM intake manifold a couple of posts above you can see there isn't supposed to be a hole there.
Old Oct 28, 2007 | 12:28 AM
  #45
RazorLab's Avatar
You guys are freaking out for no reason. The hole is in the same place as the clean manifold posted above. It's just a different camera angle.
Look where the TB cable mount threaded holes are in on the photo above, then look again at the OP's photo. See the cast upside 2 to the right of the hole? See it in both photos? Yup.
There are no welds in the OP's manifold, there is just dirt that makes it look that way.
