6 spd best place to mount a temp probe
Old Oct 25, 2007 | 08:04 PM
TempeRacerGuy's Avatar
I own an 06 MR w/ 6 spd tranny. I don't abuse my car or track it.... yet. However with all the people complaining about failures, I would like to monitor my transmission oil temperatures and put in a tranny cooler if needed.
Where is the best place to mount this oil Temp probe?
Thanks
Old Oct 25, 2007 | 08:23 PM
KenMasters's Avatar
You can have a machine shop drill and tap, or make a custom drain/fill plug for you.
That is the easiest and least evasive route.
Just my $.02
Old Oct 26, 2007 | 07:19 PM
trinydex's Avatar
that's about the only option...
Old Oct 26, 2007 | 11:03 PM
OK, that's one option.... However with the 6 speeds, the plugs are socket head bolts (that require an allan key) to remove.... so kind of hard to drill and install a probe there without completely rendering them useless.
Old Oct 27, 2007 | 01:03 PM
trinydex's Avatar
what plugs?
Old Oct 28, 2007 | 03:36 PM
KenMasters's Avatar
Again, a machine shop can build you a temp probe "PLUG" that you use a wrench to take out. your probe will be in the center of that plug.
If your going to get a cooler anyway, run a sensor inline on the hotside of the (cooler inlet) oil cooler/trans cooler.(It's all oil of some sort)
Old Oct 28, 2007 | 03:48 PM
trinydex's Avatar
bung?
if you have a tranny cooler you need a bung to run the line... so you still need the bung
Old Oct 28, 2007 | 04:21 PM
OK... Let me make this simple.
For those of you familiar with the 6 speed transmission case... Where is the best place for me to drill and tap the case to place a temperature probe?
I do not have a cooler... I want to install a temperature probe to see if I will need a cooler in the future.
I don't want to spend money at a machine shop for something I can do myself. I just don't want to crack open my tranny case to see if I have clearance for the probe.
Old Oct 31, 2007 | 06:46 PM
KenMasters's Avatar
Give Shep or TRE a call and see what they suggest.
Old Oct 31, 2007 | 09:10 PM
trinydex's Avatar
you'd prolly want a drilled hole and a welded bung for thread.
Old Oct 31, 2007 | 09:13 PM
Erik@MIL.SPEC's Avatar
Check out the "Track ****** with 6 speeds" thread in the motorsports section. One guy posted pics of his tranny cooler set-up which has a temp probe right near the drain plug.
Old Oct 31, 2007 | 09:23 PM
trinydex's Avatar
that is at the drain plug...
Old Oct 31, 2007 | 09:44 PM
Yup, I just wanted him to see it...but thanks to Davy's picture-posting madness, not we get it in this thread too
