14 psi stock?
Old Oct 27, 2007 | 04:58 PM
trboboost91's Avatar
14 psi stock?
Just got my defi boost guage hooked up and it works fine but i drove the car and only hit 14 psi which gradually rises to about 16 psi by redline.
i though these cars ran something line 19-20 psi stock?
anyone have any ideas before i dig into this?
veh does not have a boost controller.
Old Oct 27, 2007 | 05:00 PM
kreionic's Avatar
check the gauge. Run a pressurized air to the gauge and see if it matches up. Or get on a dyno and have them log boost and pay attention to the gauge. Even if the gauge is off by a few psi thats still pretty low
lemmonhead's Avatar
what gear you running it at?
Old Oct 27, 2007 | 05:01 PM
EJEvo's Avatar
Something ain't right - you should be digging into this. Stock max boost is 19, tailing off to 16 as you approach redline.
Old Oct 27, 2007 | 05:02 PM
tripperfx3's Avatar
Yea. You should be running 19psi. Also if this is only in 1st gear you might only get 14-16psi before redline.
Old Oct 27, 2007 | 05:23 PM
LoBoost's Avatar
What mods do you have if any.Your boost is pretty low like wastegate presure did you pop the wastegate vacuum line off.
Old Oct 27, 2007 | 05:26 PM
bluebyu36's Avatar
mods
Old Oct 27, 2007 | 05:38 PM
krazirob's Avatar
if you got any mods or even if you dont, it NEVER hurts to do a leak test to make sure you arent leaking air........just my thoughts
but it could be the gauge too.....leak test takes 5 min though....quick troubleshoot
Old Oct 27, 2007 | 09:28 PM
jonjon0517's Avatar
boost leak?
Old Oct 27, 2007 | 11:43 PM
EvoDom's Avatar
my evo is completelt stock....and i spike 19psi /..somethiong is deff wrong man...check it
Old Oct 28, 2007 | 12:06 AM
Shacochis06's Avatar
well atleast the defi looks good lol
Old Oct 28, 2007 | 12:52 PM
sorry guys should have posted mods
tbe
ams front mount and licp
arc box
bought the car used
Old Oct 28, 2007 | 07:50 PM
anything a previous owner could have messed up uninstalling a boost controller
if they had one on it and took it off?
just took it for another drive and it hits 13psi then gradually rises to 17 psi by
redline.
Old Oct 28, 2007 | 07:51 PM
bump to the top
i need suggestions.
anybody experience similar problem?
thanks for any help in advance
Old Oct 28, 2007 | 08:01 PM
Ultimate CC's Avatar
this is either the stock boost controller is hooked up wrong or there is boost leak, check how the controller is hooked up...
