5th/6th Gear Syncro or Clutch Adjustment?
Old Oct 29, 2007 | 06:35 AM
Last4G63's Avatar
Lately, while driving down the highway for a period of time, whenever I try and pull the gear lever out of 6th, it's somewhat "sticky" and doesn't want to pop out very easily. After I get it out and try to put it back into 5th or 6th, everything appears to be fine. I have noticed an intermittent grind occasionally when shifting into 5th gear, but 6th has never given me a problem.
Also, lately, going into 2nd is sometimes difficult without grinding to, could this be a clutch adjustment issue or the beginnings of transmission issues?
Thanks!
--------------------UPDATE------------------------
I've narrowed the issue down. Gears 1-5 work fine as long as I don't try and engage 6th gear. I can force 6th, but when I disengage (to downshift) all of the other gears seem to "lockout" and the gear lever is very "gummy" and "resistant." I played with it in the garage last night and anytime I engage 6th it appears to effect all gears, if I put it into 5th, it appears to "reset" the tranny and I can wiggle some freedom back into the gear lever.
I know many others have had this exact issues, what was the cause?
Old Oct 29, 2007 | 07:47 AM
Oracle1's Avatar
Clutch adjustment or gear linkages need adjusting IMHO
Old Oct 29, 2007 | 07:55 AM
Last4G63's Avatar
I'm going to give the clutch adjustment a shot and see how that goes. How can you adjust the gear linkage?
Old Oct 29, 2007 | 09:24 AM
Oracle1's Avatar
On UK/JDM car:
Remove battery and cover, 3 bolts triangle shape holds gear linkages, if someone moves the gears you will see them move. Loosen bolts, fiddle with linkages until happy!
Old Oct 30, 2007 | 05:01 AM
Last4G63's Avatar
I know many others have had similar issues with their 6-speed transmissions, did anyone resolve theirs or find out what was the cause of the problem?
Old Oct 31, 2007 | 05:18 AM
Last4G63's Avatar
I e-mailed Shep about this problem and his response is below...
Originally Posted by John Shepherd
It is most likely the slider that passes over the hub has burrs on it from a
missed shift or a grind on a shift. Driving it may work the burrs out a
little but most likely the slider would have to be changed out. Hope this
helps.
Thanks
John Shepherd
www.sheptrans.com
www.shepracing.com
fromWRXtoEVO
Apr 21, 2014 06:57 PM
AFD
Dec 8, 2011 12:37 PM
pb91
Jun 8, 2011 02:44 PM
Last4G63
72
May 3, 2009 05:40 PM
EvoIXMRT
11
Oct 31, 2007 05:10 AM
