EVO Green Options/Questions
Old Nov 1, 2007 | 09:05 AM
EVO Scotland's Avatar
Hi,
Goin to go with a Evo Green from EVO400 in the uk.
http://www.evo400.co.uk/index.php?ca...&ProductID=155
as you can see there are alot of options eg bb con ported shroud etc, are they worth it??
Also im goin to be running it on std internals, which aint done in the uk at around 1.5/1.6 bar of boost. on 99ron fuel.
I know alot of you guys in America are running on std internals, have you had any issues??
Thanks
Old Nov 1, 2007 | 09:10 AM
Soon2BEVO's Avatar
I have not heard one single issue and Im sure it would be posted all over if there was. I definitely would not worry about it. As for the options, definitely get it ported. Ported shroud is pretty cool, Id get it! BB... ah mine as well!
Old Nov 1, 2007 | 09:13 AM
thatsMR2u's Avatar
ported shroud will help with compressor surge which i know the evo 9 compressor non ball bearing has no problems with- but as for ball bearing conversion that would be sick for both quicker spool up and reliability- i say get the ball bearing option only unless they have a porting option also- then port and ceramic coat your exhaust manifold!
then add methanol injection and run 28-30 psi!
Old Nov 1, 2007 | 09:23 AM
thanks guys, quick anwers on here!!
Im going with a Mynes manifold
https://www.evolutionm.net/forums/sh...ighlight=mynes
Im also at the moment running Tomei 270 cams
So the bb conversion and a ported shroud would be the best option then??
Glad to here nobody has had problems on std internals
Old Nov 1, 2007 | 09:28 AM
thatsMR2u's Avatar
well the ported shroud has a huge intake diameter- so if ur still running a MAF sensor it may be hard to find an intake pipe to fit it and it may mess with ur maf readings- so porting the exhaust side would be beneficial but i dont think the ported shroud is worth the extra money.
Old Nov 1, 2007 | 09:32 AM
No Im no longer running the map mate, i have a Apexi Power FC d Jetro fitted to the car along with a Apexi AVCR Boost Controller
Old Nov 1, 2007 | 04:03 PM
thatsMR2u's Avatar
then it sounds like the ported shroud may just be worth it for you! cheers
Old Nov 1, 2007 | 05:30 PM
sparky's Avatar
Is your BOV venting to atmoshere or recirculating? If it is VTA, then you could try something that I think might give you the best breathing Green out there:
Since you'll be getting the compressor housing with the 4" inlet, then have ITG make you an air filter with a 5" outlet. This will enable you to run a 5" I.D. inlet pipe/hose from the filter outlet to just ahead of the compressor housing inlet, where you would reduce from 5" to 4". Your Green should breath freely then. Of course you may have a hard time finding an UICP that will fit over it all.
Old Nov 1, 2007 | 05:34 PM
Qatar_Evo's Avatar
Damn you will pay that much??
order one from here better for you
Old Nov 1, 2007 | 05:37 PM
dudical26's Avatar
just take your green back from your mate who has your old one. hehe
Old Nov 2, 2007 | 09:55 AM
Everything here is expensive!! But u get used to it, Yeah I have bought for America before and been lucky not to get caught by customs if you do it ends up costing you more!!!
Old Nov 2, 2007 | 10:07 AM
06MRV8Killer's Avatar
Excuse the ignorance but why would you have to worry about customs?
Old Nov 5, 2007 | 08:02 AM
^ curious about this....
Old Jan 21, 2008 | 11:13 AM
Ducu's Avatar
Guys... im puting evo green and wiseco pistons, forged rods...and so on.
My other mods are in my sig...
what should i expect on fuel pump...WHAT NUMBERS?
Old Jan 21, 2008 | 09:31 PM
Mike@Mynes's Avatar
Certain European countries have VAT (Value Added Tax) that they tack on imported items... i donno what the % is, but i've heard it's pretty high. There are ways to get around this, but that depends on the luck of the draw as well
