Help me understand this boostcreep problem
Old Jan 20, 2008 | 01:50 PM
sparky's Avatar
Originally Posted by sllt1776
ever get this figured out? I am having the same issue since yesterday. All i did was replace the stock WGAwith a Forge Unit. I'm hoping i just need to adjust it.
Could you provide more specifics as to what issue you are experiencing??????????
Old Jan 20, 2008 | 01:54 PM
sparky's Avatar
Are you running a a stock VIII 16G turbo with the original 9.8 hotside?
Old Jan 20, 2008 | 01:57 PM
sparky's Avatar
When you installed the new Forge WGA did you put any pretension on the WG by shortening the actuator rod, or did you just slip the turnbuckle onto the flapper valve´s pivot arm without having to yank hard on it?
Old Jan 20, 2008 | 02:05 PM
sparky's Avatar
What gear are you setting boost in?
Nelson999
E85 / Ethanol
178
Dec 6, 2017 09:55 AM
ps3kgt
Lancer Troubleshooting
Oct 11, 2015 12:02 PM
ReignMan24
37
Feb 27, 2013 08:51 PM
haloevolution45
10
Sep 10, 2007 10:17 PM
negativeB
16
Dec 26, 2004 09:10 PM
