which turbo, help me decide
Old Nov 2, 2007 | 11:49 AM
crcain's Avatar
Originally Posted by Evo8Emperor
Now with all that in mind seeing he was already running 30 psi that kind of takes the 3065 out the picture and the green even though it wasnt a option in the beginning considering his manifold is t4-t3. So there only so many options if he goes with the 3076 how long you think its really going to last running 30psi ? Thats why i said IMO id go with the 35R. Hes got everything he needs to have it make some good numbers.
A) When choosing a turbo for a particular application... what boost you may have run in the past really has no bearing in what you might choose going forward.
B) Turbo failures are very uncommon. You could run a Green, GT30, 50-Trim, or even a std turbo at 30 psi everyday and provided it's fed oil and water properly, I'd be surprised if the turbo did not outlast the engine everytime.
Old Nov 2, 2007 | 04:25 PM
Dapper Dan's Avatar
very true...mt stocker has 28 psi fed through it for months....and it kept on spooling.... im looking for a good street turbo that can maybe get me into the 10s....i may consider a 35r, but i think im leaning more towards a 3076 or a 3065..
Old Nov 3, 2007 | 07:24 AM
20Grockit's Avatar
id go with either the fp green or a gt30r or even a tme 20g-9
Old Nov 3, 2007 | 01:54 PM
andrew_sup's Avatar
God that is a bad advice above ^^^^^
Lag is real and a 2 litre with GT35 is IMHO not the best combination at all. Dave Buschur himself I believe said he did not like the combination for a daily driver and preferred a Evo Green on a 2 litre.
An Evo Green car will likely make more hp and torque than a GT35R up to 5k rpm.
If you think driving a GT35R on a 2 litre around town, through bends, out of stoplights, etc is more fun than a Evo Green on a 2 litre I think your smoking something probably.
Think of it this way... your car is dead from 1-4k rpm... then at 4k you'll finally be making some power, but still slower than a green. Then finally at 5k she wakes up and is faster than the green, BUT... on pump there probably will never be more than a 100 hp between the two.
true that
Old Nov 3, 2007 | 09:12 PM
sparky's Avatar
If it was me and I wanted better spool than a 35R but still needed to retain mid-ten second capabilities, I'd get an HTA 3065. It should be very bit as good as a 35R up to 30#, from what I understand.
Old Nov 3, 2007 | 09:38 PM
mchuang's Avatar
Why do people keep saying 3065. The guy said he had a 3076 and a 50trim which means he has a dam t3 flanged manifold, the 3065 is not t3 flanged.
Old Nov 3, 2007 | 10:42 PM
sparky's Avatar
What footprint does the turbine housing of a 3065 have anyway?
Sorry if this is OT.
Old Nov 4, 2007 | 12:47 AM
Evogasm's Avatar
i vote 3076R twin scroll
Skidonner90
32
Oct 9, 2015 05:53 PM
vwjeff
43
Nov 16, 2009 09:57 PM
EvoVIIIFL
11
Feb 20, 2007 01:27 PM
krnzzang84720
Lancer Aftermarket Forced Induction Tech
26
Apr 22, 2006 12:43 PM
